I migrated to version 5.2 this morning and from the main page (overview) remains completely empty
A return to 5.1 allows you to display it correctly again
an idea?
an idea?
English please, this is an international community!
5.2 is our development version and could be sometimes unstable, even if it is rare in practice.
There were progressive upgrades to Karaf 4.4.10 in all our repo during the 2 last days.
I have not yet tested the last changes but snapshot 5181 should embed the full migration to Karaf 4.4.10.
with the snapshot 5181 the problem remains: homepage displays the title but everything else is empty
I’m on 5.2.M1 and don’t have any problems with MainUI. Problem seems to be different. Did you try cache clean?
yes i did
Even if I edit the page directly the screen is empty. However, in the code tab, it is present
If an ultra recent snapshot is not working, try the 5.2 milestone 1 which is working well.
It was on 5.2. M1 that I had noticed the problem. I then installed the last snapshot that does not change anything…
About 2-3 weeks ago I had installed a snapshot of the 5.2 that worked perfectly, unfortunately I did not rate the number…
