Hi
I started to migrate from my running OH1 to OH2. The OH1 is running on RaspberryPi 3. No I went through the migration guid and installed all needed package for OH2 over apt-get, fallowing this documentation: http://docs.openhab.org/installation/linux.html#package-repository-installation
If I start the service I get following output:
● openhab2.service - The openHAB 2 Home Automation Bus Solution
Loaded: loaded (/lib/systemd/system/openhab2.service; disabled)
Active: active (running) since Sun 2017-11-05 11:40:12 CET; 39s ago
Docs: http://docs.openhab.org
Main PID: 25460 (karaf)
CGroup: /system.slice/openhab2.service
├─25460 /bin/bash /usr/share/openhab2/runtime/bin/karaf server
└─25630 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/...
Nov 05 11:40:12 raspberrypi systemd[1]: Started The openHAB 2 Home Automation Bus Solution.
Nov 05 11:40:12 raspberrypi start.sh[25460]: Launching the openHAB runtime...
If I go to http://raspberrypi.local:8080/habmin/index.html#/bindings I get an popup error “Server is not running”.
I’m looking now for 3 day for this problem and tried several things, but nothing is working. Do someone have any idea?
Thank you in advance for your answer.
