xefil
(X3fil)
February 8, 2016, 5:35pm
#1
I would like to migrate my setup (openhab1.6.1) to OpenHAB2.
I’ve following questions:
Actually I’m using following bindings:
a) MQTT
b) MySQL persistent
Are those available on OpenHAB2?
Is the actual configuration (simple straigt forward) compatible or do I need to rewrite all?
Can I migrate the old persistent data hold into MySQL to the new OpenHAB2? Is it in case migrated automatically?
Does the actual iPhone app work with OpenHAB2 as well?
I’m running OpenHAB on an ARM device.
Thanks for any help!
Simon
sihui
(SiHui)
February 8, 2016, 5:47pm
#2
[quote=“xefil, post:1, topic:7310, full:true”]
Are those available on OpenHAB2?[/quote]
You will find all v2 addons and the compatibility table here:
https://github.com/openhab/openhab-distro/blob/master/docs/sources/addons.md#list-of-available-add-ons
xefil:
Yes, it should (and was for me). But the item definition for addons v2 is a bit different, because you can do that now via PaperUI.
xefil
(X3fil)
February 9, 2016, 7:46am
#3
Thanks for the answers.
What about those questions? Any informations?
Then, I’m searching a step-by-step documentation to start with openHAB2, but cannot find it. Ideas where to look for?
Thank you,
Simon
sihui
(SiHui)
February 9, 2016, 7:51am
#4
[quote=“xefil, post:3, topic:7310, full:true”]
3. Can I migrate the old persistent data hold into MySQL to the new OpenHAB2? Is it in case migrated automatically?
4. Does the actual iPhone app work with OpenHAB2 as well?[/quote]
Sorry, no idea.
https://github.com/openhab/openhab-distro/blob/master/docs/sources/getting-started.md
