I tried to migrate from RPI3 to RP4.
I did image of current version and then with second card I started rpi4. Everything seems to work correctly with one small “detail” - zwave. I have Aeotec controller but RPI4 doesn’t see it.
My serial is not listed
ls -l /dev/serial/by-id
ls: cannot access ‘/dev/serial/by-id’: No such file or directory
I have also zigbee controller but it discovered correctly
Did I missed something?
After switching to RPI3 controller works correctly
Although that is true the error stated indicated an incorrect device name. The stick would still be seen bu the OS, but as a non-functional USB3 device .
