Just recently upgraded the docker image from registry, reset & restart the container on Synology diskstation. Since then I cannot reach OH anymore.
The update.log looks fine as it finishes with SUCCESS: openHAB updated from 4.0.4 to 4.1.0
openhab.log and events.log stay zero size.
Checking the status of openhab with
$ docker exec -it openhab /openhab/runtime/bin/status
returns Running… seems to be fine
Opening the OH https or http website ends with “refused to connect”
curl -k https:// xx :8444
curl: (7) Failed to connect to 192.168.48.192 port 8444 after 2042 ms: Couldn’t connect to server
or
curl http:// xx :8081
shows the same problem.
Inspecting the docker container
$ docker inspect openhab
indicates the container’s running state, but with failing health check.
Reported environment parameters also look fine:
“Env”: [
“PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin”,
“CRYPTO_POLICY=unlimited”,
“EXTRA_JAVA_OPTS=-Duser.timezone=Europe/Berlin”,
“GROUP_ID=9001”,
“KARAF_EXEC=exec”,
“LC_ALL=en_US.UTF-8”,
“LANG=en_US.UTF-8”,
“LANGUAGE=en_US.UTF-8”,
“OPENHAB_BACKUPS=/openhab/userdata/backup”,
“OPENHAB_CONF=/openhab/conf”,
“OPENHAB_HOME=/openhab”,
“OPENHAB_HTTP_PORT=8081”,
“OPENHAB_HTTPS_PORT=8444”,
“OPENHAB_LOGDIR=/openhab/userdata/logs”,
“OPENHAB_USERDATA=/openhab/userdata”,
“USER_ID=9001”,
“JAVA_VERSION=17”,
“JAVA_HOME=/usr/lib/jvm/java-17-openjdk-amd64”
ssh into the docker container, checking the running process by ps -edlaf:
0 S openhab 25 1 0 80 0 - 961839 futex_ 10:49 pts/0 00:00:14 /usr/lib/jvm/java-17-openjdk-amd64/bin/java
-XX:-UsePerfData
-Dopenhab.home=/openhab -Dopenhab.conf=/openhab/conf
-Dopenhab.runtime=/openhab/runtime
-Dopenhab.userdata=/openhab/userdata
-Dopenhab.logdir=/openhab/userdata/logs
-Dfelix.cm.dir=/openhab/userdata/config
-Djava.library.path=/openhab/userdata/tmp/lib
-Djdk.util.zip.disableZip64ExtraFieldValidation=true
-Djetty.host=127.0.0.1
-Djetty.http.compliance=RFC2616
-Dorg.apache.cxf.osgi.http.transport.disable=true
-Dorg.ops4j.pax.web.listening.addresses=127.0.0.1
-Dorg.osgi.service.http.port=8081
-Dorg.osgi.service.http.port.secure=8444
-Djava.awt.headless=true -Dfile.encoding=UTF-8
indicates the expected running OH parameters as given by the container env parameters.
Within the container I could also reproduce the failing health check:
root@openhab:/openhab# curl -f http://localhost:8081
curl: (7) Failed to connect to localhost port 8081: Connection refused
With netstat I could not identify any listeners on the ports 8081 and 8444:
root@openhab:/openhab# netstat -nap
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 127.0.0.11:47117 0.0.0.0:* LISTEN -
tcp 0 0 127.0.0.1:44699 0.0.0.0:* LISTEN -
udp 0 0 127.0.0.11:59212 0.0.0.0:* -
udp 0 0 0.0.0.0:8472 0.0.0.0:* -
Active UNIX domain sockets (servers and established)
Proto RefCnt Flags Type State I-Node PID/Program name Path
unix 2 STREAM CONNECTED 78605677 -
unix 3 STREAM CONNECTED 78603582 -
unix 3 STREAM CONNECTED 78606571 -
unix 3 STREAM CONNECTED 78606572 -
unix 3 STREAM CONNECTED 78603583 -
Thus there seems no exiting listerners be active. Comparing with other docker containers, I would expect the web server sitting on the configured ports.
Any idea what is going wrong with that docker image? I could not find any further logging sources explaining what’s going on.
