I’m running OH 3.4.4 on a Rocky Linux 8.x system. I do have java-17 installed from the appstream repo. Just tried to update OH to 4.0.1-1 and it won’t start. I thought the java update was the only requirement but I guess I missed something else.
Is there a list or guide for updating to 4.0 when it’s running on a Rocky Linux system?
Originally I setup the repo in yum/dnf (JFrog) and ran a typical “dnf install openhab openhab-addons”. Then I started setting up the hardware and the config I want. The system is a little fanless mini PC, Celeron N3160 and 4G memory and a 120G Kingston SSD. I believe the initial OS install I selected typical workstation and let it pick whatever packages the installer thought necessary.
I’ve disabled that repo right now so it won’t try to update to OH4.
To try to update to 4 this morning I installed java-17-openjdk and java-17-openjdk-headless. Then I reenable the stable repo and updated openhab and openhab-addons to the 4.0.1-1 versions. After that it wouldn’t start. Reinstalled the 3.x version using rpm and things start working again.
Is that enough detail about how I have my system setup?
