I am currently running openHAB 3 on a RaspBerry Pi 3 using the RazBerry board. I am using a number of FIBARO RollerShutters 2 and 3, FIBARO Single Switch 2 and Sensitive Strips Guard.
I am planning to migrate everything to a new RaspBerry Pi 4 and I am considering to use a new Z-WAVE Controller on the new Pi 4 (probably Nortek or UZB). However, I do not want to exclude the devices and reset and include them on the new controller.
Would this approach work or is there another easy way to migrate the Z-WAVE network?
Setup the new environment Pi 4 and UZB
Include the new environment as secondary controller in the Z-WAVE network on the OLD Pi
Set the new controller to be the main one and the old controller to be the secondary one
Finalize the setup of the new openHAB 3 instance
Remove the OLD controller on Z-WAVE network and disconnect the old system
I don’t mind to recreate all things, items, automations, but as said, I do NOT want to reset the devices.
Thanks in advance to anyone responding.
PS: I read through some of the post covering this topic, but could not really understand or figure out the best approach doing so.
Why don’t you just move the RaZberry board to the new Pi? Should do right away.
If by all means you want to change the Z-Wave controller, then you can install Z-Way from zwave.me, you should be having a license when you have a RaZberry.
Use this tool to backup your RaZberry and to restore the config to the UZB.
I’d move the RaZberry and keep the UZB as a spare part.
The RazBerry does not fit into the new housing. Also I want to be flexible with respect to the platform. Perhaps I move to something else then Pi in the future.
I understand, that Z-Way and openHAB cannot be active at the same time. Correct?
So I would have to …
Shutdown the openHAB service
Install and start Z-Way
Force remove some failed devices I have (broken not functioning devices) with Z-Way
Do the backup and the restore on the new UZB Stick
Shutdown Z-Way (perhaps uninstall to avoid problems)
Start openHAB service again
Anything else to pay attention to?
Would the other procedure also work, that I have listed in the first post?
I am facing something similar. Moving away from a Raspberry/Razberry config towards a VM in my homelab. Need to move my Things from the RAZberry to the Z-Wave Stick 7 by AEOTEC.
I could get into the Z-Wave network by using the stick in my PC with Zensys Tools and somehow the Stick is now in my network. Moving it to Node 1 seems to be a problem though. Any recommendations ? Did you have any success ?
But in any case I’m thinking about switching to a USB z-wave stick just to become a bit more flexible in case something happens with my raspi or I want to switch to a VM or container or whatever.
And obviously I don’t want to reintegrate all things if I can somehow avoid it.
Above there is one proposal to backup the razberry via z-way and restore to UZB. Is that actually something which is supposed to work. Does anyone know, tried this before?
Would this work with other z-wave sticks (maybe not, right?)
Then there was another idea to connect the razberry with a usb-serial adapter and connect it then via USB if I understand correctly? Does anyone have a bit more pointers how this would look like?
