ROS 7.18 seemingly changed something. First of all Mikrotik is now logging all logins and logouts of openhab, didnt do that before.
But also openhab is spamming my log with stack-traces (see below). Is there anything I can try or do? The items are still filled with values and there are no errors shown in the things. So seems “just” like an issue that is in the logs. But its hard to see anything else in the log.
ERROR: RouterOS cache refresh failed in mikrotik:routeros:Mikrotik_hEX_refresh_E50UG due to Mikrotik API error
... 13 more
2025-03-12 09:06:01.474
at me.legrange.mikrotik.impl.ApiConnectionImpl$SyncListener.getResults(ApiConnectionImpl.java:474) ~[?:?]
Caused by: me.legrange.mikrotik.ApiConnectionException: Command timed out after 60000 ms
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) [?:?]
at org.openhab.binding.mikrotik.internal.handler.MikrotikRouterosBridgeHandler.scheduledRun(MikrotikRouterosBridgeHandler.java:190) ~[?:?]
at org.openhab.binding.mikrotik.internal.handler.MikrotikRouterosBridgeHandler.performRefresh(MikrotikRouterosBridgeHandler.java:202) ~[?:?]
at org.openhab.binding.mikrotik.internal.model.RouterosDevice.refresh(RouterosDevice.java:167) ~[?:?]
at org.openhab.binding.mikrotik.internal.model.RouterosDevice.updateResources(RouterosDevice.java:347) ~[?:?]
at me.legrange.mikrotik.impl.ApiConnectionImpl.execute(ApiConnectionImpl.java:75) ~[?:?]
at me.legrange.mikrotik.impl.ApiConnectionImpl.execute(ApiConnectionImpl.java:117) ~[?:?]
at me.legrange.mikrotik.impl.ApiConnectionImpl$SyncListener.access$100(ApiConnectionImpl.java:436) ~[?:?]
at me.legrange.mikrotik.impl.ApiConnectionImpl$SyncListener.getResults(ApiConnectionImpl.java:482) ~[?:?]
me.legrange.mikrotik.MikrotikApiException: Command timed out after 60000 ms
/interface/wifi/registration-table/print
and
/interface/wireless/registration-table/print
I’m using CapsMan and only have the wireless package installed (not the wifi-qcom or wifi-qcom-ac). The router I’m connecting to doesn’t have any internal wifi interfaces.
It began after I upgraded from version 7.17.1 to 7.18.
Didn’t see anything obvious here: MikroTik · Downloads
Running OpenHAB 4.3.3 release build, “official” Mikrotik binding from the store.
In my case presence detection is extremely slow, It takes (openhab/the binding) forever to detect that my phone is connected to the wifi. This used to be within a minute or so. (I have no wifi issues, my phone connects as it used to)
I also have the error.
As an addendum: On my Raspberry Pi 4, one CPU core is permanently 100% utilized by the binding.
As soon as I deactivate the binding, the load goes down immediately.
oh thanks for pointing out the load-issue, I was wondering why my USV is reporting a higher load and also why my total power consumption was rising. At least found that culprit. I will disable the binding for now.
No problem.
Do you also have the following in the log when binding is deactivated? [ERROR] [andler.MikrotikRouterosBridgeHandler] - RouterOS device is null in scheduledRun ?
Comes up every 10 seconds for me.
I only have one MikroTik router.
Update: After a reboot of openhab, the Error is gone.
