Is anyone getting this error message or any others when trying to setup a Mikrotik router with the binding? I seem to have tracked it down to my new AX3 router that does not support capsman commands and I am making some changes to the binding at the moment so would be great to hear if anyone has issue whilst I am the API docs open and fresh in my head.
I am getting this error that stops the bridge coming online.
2024-07-14 17:18:25.462 [ERROR] [andler.MikrotikRouterosBridgeHandler] - RouterOS cache refresh failed in mikrotik:routeros:22fb1c4dca due to Mikrotik API error
me.legrange.mikrotik.MikrotikApiException: no such command prefix
at me.legrange.mikrotik.impl.ApiConnectionImpl$SyncListener.getResults(ApiConnectionImpl.java:482) ~[?:?]
at me.legrange.mikrotik.impl.ApiConnectionImpl$SyncListener.access$100(ApiConnectionImpl.java:436) ~[?:?]
at me.legrange.mikrotik.impl.ApiConnectionImpl.execute(ApiConnectionImpl.java:117) ~[?:?]
at me.legrange.mikrotik.impl.ApiConnectionImpl.execute(ApiConnectionImpl.java:75) ~[?:?]
at org.openhab.binding.mikrotik.internal.model.RouterosDevice.updateCapsmanRegistrations(RouterosDevice.java:263) ~[?:?]
at org.openhab.binding.mikrotik.internal.model.RouterosDevice.refresh(RouterosDevice.java:163) ~[?:?]
at org.openhab.binding.mikrotik.internal.handler.MikrotikRouterosBridgeHandler.performRefresh(MikrotikRouterosBridgeHandler.java:202) ~[?:?]
at org.openhab.binding.mikrotik.internal.handler.MikrotikRouterosBridgeHandler.scheduledRun(MikrotikRouterosBridgeHandler.java:190) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) [?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
Caused by: me.legrange.mikrotik.impl.ApiCommandException: no such command prefix
at me.legrange.mikrotik.impl.ApiConnectionImpl$Processor.run(ApiConnectionImpl.java:270) ~[?:?]
2024-07-14 17:18:25.467 [DEBUG] [krotik.internal.model.RouterosDevice] - Logging out of 192.168.10.1
2024-07-14 17:18:25.467 [DEBUG] [krotik.internal.model.RouterosDevice] - Closing connection to 192.168.10.1
2024-07-14 17:18:25.468 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mikrotik:routeros:22fa' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): no such command prefix
After fault finding and fixing the issue I found a number of users have had the same problem here:
The problem stems from:
The 'WiFi' configuration menu, introduced in RouterOS 7.13, is a RouterOS menu for managing Wi-Fi 5 wave2 and newer WiFi interfaces.
API command /interface/wireless/registration-table/print now needs to be /interface/wifi/registration-table/print and a number of other similar changes.
Hi matt1,
I am also interested in testing the fix. Currently I have two devices configured in openHAB 4.2.2 with the bundle from marketplace:
6.49 LTS: Works (I can read the uptime in openHAB for example) but this error is shown in the logs RouterOS device is null in scheduledRun
7.12: Works not. Get this error: RouterOS cache refresh failed due to Mikrotik API error
I can confirm that with the org.openhab.binding.mikrotik-4.3.0-SNAPSHOT.jar from 2024-10-12 it works for both versions (I can read the uptime in openHAB). But the [ERROR] [andler.MikrotikRouterosBridgeHandler] - RouterOS device is null in scheduledRun is still there.
Have you restarted openHAB to see if its an old thread still running? I can not see how it can be null as this would be a config error and that should cause the thing to not come online. If a restart does not fix it, then you will need to provide TRACE level logs when you press PAUSE and then UNPAUSE the thing so it connects. That may provide a clue where to look.
Since I can not reproduce this and can not see an obvious bug this may be harder to track down so hopefully a restart fixes it.
Good my guess is it was a glitch from changing the jar over whilst the binding was running. If you notice anything is not working let me know whilst the code is fresh in my head. I had to make s
Changes to get the wifi signal strengths to show correct under v7 so other changes may be needed.
