I’ve upgraded from OH 2.2 to 2.3 and am having problems with the Milight binding.
The issue is that disco mode no longer works. I don’t have much luck upgrading OH since a similar issue with disco mode occurred going from OH 2.1 to OH 2.2.
I have the following item defined:
Dimmer discoModeGroup5 {channel="milight:rgbLed:ACCF23A6C9F8:1:animation_mode_relative", autoupdate="false"}
Sending an “INCREASE” command to the item results in the following NullPointerException which looks to be coming from ESH rather than the binding:
2018-09-10 12:58:35.043 [ERROR] [me.core.internal.events.EventHandler] - Dispatching/filtering event for subscriber 'org.eclipse.smarthome.core.events.EventSubscriber' failed: null
at java.util.concurrent.ConcurrentHashMap.get(ConcurrentHashMap.java:936) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.lambda$2(CommunicationManager.java:253) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.toAcceptedType(CommunicationManager.java:329) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.lambda$8(CommunicationManager.java:305) ~[?:?]
at java.util.stream.ForEachOps$ForEachOp$OfRef.accept(ForEachOps.java:184) [?:?]
at java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:175) [?:?]
at java.util.Spliterators$ArraySpliterator.forEachRemaining(Spliterators.java:948) [?:?]
at java.util.stream.ReferencePipeline$Head.forEach(ReferencePipeline.java:580) [?:?]
at java.util.stream.ReferencePipeline$7$1.accept(ReferencePipeline.java:270) [?:?]
at java.util.concurrent.ConcurrentHashMap$ValueSpliterator.forEachRemaining(ConcurrentHashMap.java:3566) [?:?]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481) [?:?]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471) [?:?]
at java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:151) [?:?]
at java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:174) [?:?]
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) [?:?]
at java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:418) [?:?]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.handleEvent(CommunicationManager.java:298) [108:org.eclipse.smarthome.core.thing:0.10.0.oh230]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.receiveCommand(CommunicationManager.java:253) [108:org.eclipse.smarthome.core.thing:0.10.0.oh230]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.receive(CommunicationManager.java:135) [108:org.eclipse.smarthome.core.thing:0.10.0.oh230]
at sun.reflect.GeneratedMethodAccessor14.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [101:org.eclipse.smarthome.core:0.10.0.oh230]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [101:org.eclipse.smarthome.core:0.10.0.oh230]
@sjka is this the same issue as https://github.com/eclipse/smarthome/pull/5754
