Milight Binding keeps disconnecting and reconnecting to V3 bridges with OH2
Just started my trial switch from openHAB 1 to openHAB 2 and msot htings are going ok with switching over. One major issue I haven’t had any luck resolving is with the Milight Binding 2. I have manually definded four bridges in the .things file
Bridge milight:bridgeV3:ACXXXXXXXXXX “Bridge1” [ADDR=“192.168.0.15”, ID=“ACXXXXXXXXXX”] {
Thing rgbLed 1 “Wohnzimmer Decke”
Thing rgbLed 2 “Wohnzimmer Stehlampe”
Thing rgbLed 3 “Wohnzimmer Wand 1”
Thing rgbLed 4 “Wohnzimmer Wand 2”
In the logs I keep gettin the following though:
2018-03-07 15:46:32.466 [hingStatusInfoChangedEvent] - ‘milight:bridgeV3:ACXXXXXXXXXX’ changed from ONLINE to OFFLINE: Bridge did not respond or the bridge’s MAC address does not match with your configuration!
2018-03-07 15:46:32.469 [hingStatusInfoChangedEvent] - ‘milight:rgbLed:ACXXXXXXXXXX:1’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-03-07 15:46:32.472 [hingStatusInfoChangedEvent] - ‘milight:rgbLed:ACXXXXXXXXXX:3’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-03-07 15:46:32.475 [hingStatusInfoChangedEvent] - ‘milight:rgbLed:ACXXXXXXXXXX:4’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-03-07 15:46:32.478 [hingStatusInfoChangedEvent] - ‘milight:rgbLed:ACXXXXXXXXXX:2’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
and in the PaperUI Things list the bridges keep alternating between offline and online. For the brief moments when they are online they do function well, but it’s all very intermittently.
“Bridge did not respond or the bridge’s MAC address does not match with your configuration!”
The MAC addresses (and IP addresses) are all fine and have been double and tripple checked :wink:
Anyone with similar issues or any ideas what I could try to resolve this?
Many thanks.
EDIT: Tested with OH2 stable 2.2 and latest 2.3 Snapshot Build #1224
Same here, offline online
2018-04-05 21:25:51.362 [hingStatusInfoChangedEvent] - ‘milight:bridgeV3:ACCF23C3B230’ changed from ONLINE to OFFLINE: Bridge did not respond or the bridge’s MAC address does not match with your configuration!
2018-04-05 21:25:51.364 [hingStatusInfoChangedEvent] - ‘milight:rgbLed:ACCF23C3B230:1’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-04-05 21:26:01.531 [hingStatusInfoChangedEvent] - ‘milight:bridgeV3:ACCF23C3B230’ changed from OFFLINE: Bridge did not respond or the bridge’s MAC address does not match with your configuration! to ONLINE
2018-04-05 21:26:01.534 [hingStatusInfoChangedEvent] - ‘milight:rgbLed:ACCF23C3B230:1’ changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
running OH2 stable 2.2
