Milight Color Change and back to white light
Color Living_L “Living Room” [“Lighting”] {channel=“milight:rgbwwLed:F0FE6B2DC3FC:1:ledcolor”}
So a quick question that has been bothering me for a while. I can turn my Milight bulb off and on using alexa in white light mode.
If I ask Alexa to change the color to red it does it but when I ask to change it back to white light it goes to a dimmed color change version instead of actually turning into white light mode. Unless I use the app and change it again.
Am I missing a trick ?
This works seemlessly with a different binding which requires a $10 opensource hub to be flashed and MQTT to be setup.
What do you mean
