Hi, I’ve got my first milight working in OH2 using the PaperUI. The wifi bridge is found, as is the light and all the things for colour and brightness and the PaperUI sliders work; everything appears to function from within the {PaperUI).
I want to get it working in the classic UI so that it also works for the phone app, for brightness and colour and the other effects available but I’m having trouble with the syntax and trying to work out exactly what I need now in OH2 thats different to OH1. I did have it working in OH1.The documentation in the binding is good, but its a bit confusing as to what is needed and what isn’t, for example do I need a /services/milight.cfg or not?
Also on the classic UI the slider on the right appears as a down arrow next to an up arrow, not an actual slider. Is that the way it is supposed to appear? When I hit the up arrow I see in the events.log
Item ‘RGBW_SPARE_POWER’ received command INCREASE
however from the PaperUI when I use the thing slider I see in the log
Item ‘RGBW_SPARE_POWER’ received command 90
RGBW_SPARE_POWER changed from 100 to 90
It seems like 2 different commands are being sent, or my sitemap is still incomplete. Is there a way to get my slider in sitemap to do what the PaperUI slider is doing?
This is absolute normal behaviour. ClassicUI cannot render a slider, instead it schows the arrows.
The underlying Dimmer item is able to handle both commands.
If you want to see a slider in Web UI, please use BasicUI.
