I have OpenHab running on Linux with openjdk version “1.8.0_91”.
I am using distribution-1.8.3-runtime with 1.8.3 of the Milight bindings.
It controls a single Milight bridge that has three groups of globes set to it.
I have tried a few different configurations in OpenHab but my issue persists. The current setup is as follows:
Switch Light_LivingRoom "Living Room Lights"
Dimmer Light_LivingRoomB “Living Room Dimmer” {milight=“bridge1;3;brightness”}
Dimmer Light_LivingRoomT “Living Room Temp” {milight=“bridge1;3;colorTemperature”}
I then have a rule to turn the brightness and warmth to 100% when the switch is turned on and a rule to turn the brightness to zero when the switch is turned off.
The lights on channel 3 behave as expected.
My issue, however, is that when I turn this switch on, the lights on channel two dim to about 30% and I can’t work out why.
This happens even if I remove all mention of channel two from the OpenHab config. There is also no mention of channel two being changed in the logs when this happens.
A snippet of the logs from when this has happened is below.
Does anyone have any ideas or suggestions?
media-halley logs # tail -f openhab.log | grep -i milight
17:44:14.353 [DEBUG] [.o.b.m.internal.MilightBinding:96 ] - milight: item is of type brightness
17:44:14.353 [DEBUG] [.o.b.m.internal.MilightBinding:111 ] - milight: command is of type PercentType
17:44:14.353 [DEBUG] [.o.b.m.internal.MilightBinding:192 ] - milight: sendPercent
17:44:14.353 [DEBUG] [.o.b.m.internal.MilightBinding:664 ] - milight: sendOff
17:44:14.353 [DEBUG] [.o.b.m.internal.MilightBinding:350 ] - milight: sendDecrease
17:44:14.354 [DEBUG] [.o.b.m.internal.MilightBinding:383 ] - milight: Bulb ‘3’ getting decreased to '91’
17:44:14.354 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '34:00:55’
17:44:14.354 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet ‘34:00:55’ to bridge ‘bridge1’ (192.168.8.11:8899)
17:44:14.454 [DEBUG] [.o.b.m.internal.MilightBinding:350 ] - milight: sendDecrease
17:44:14.455 [DEBUG] [.o.b.m.internal.MilightBinding:383 ] - milight: Bulb ‘3’ getting decreased to '82’
17:44:14.455 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '34:00:55’
17:44:14.456 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet ‘34:00:55’ to bridge ‘bridge1’ (192.168.8.11:8899)
17:44:14.556 [DEBUG] [.o.b.m.internal.MilightBinding:350 ] - milight: sendDecrease
17:44:14.557 [DEBUG] [.o.b.m.internal.MilightBinding:383 ] - milight: Bulb ‘3’ getting decreased to '73’
17:44:14.557 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '34:00:55’
17:44:14.557 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet ‘34:00:55’ to bridge ‘bridge1’ (192.168.8.11:8899)
17:44:14.658 [DEBUG] [.o.b.m.internal.MilightBinding:350 ] - milight: sendDecrease
17:44:14.658 [DEBUG] [.o.b.m.internal.MilightBinding:383 ] - milight: Bulb ‘3’ getting decreased to '64’
17:44:14.658 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '34:00:55’
17:44:14.659 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet ‘34:00:55’ to bridge ‘bridge1’ (192.168.8.11:8899)
17:44:14.759 [DEBUG] [.o.b.m.internal.MilightBinding:350 ] - milight: sendDecrease
17:44:14.760 [DEBUG] [.o.b.m.internal.MilightBinding:383 ] - milight: Bulb ‘3’ getting decreased to '55’
17:44:14.760 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '34:00:55’
17:44:14.760 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet ‘34:00:55’ to bridge ‘bridge1’ (192.168.8.11:8899)
17:44:14.861 [DEBUG] [.o.b.m.internal.MilightBinding:350 ] - milight: sendDecrease
17:44:14.861 [DEBUG] [.o.b.m.internal.MilightBinding:383 ] - milight: Bulb ‘3’ getting decreased to '45’
17:44:14.862 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '34:00:55’
17:44:14.862 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet ‘34:00:55’ to bridge ‘bridge1’ (192.168.8.11:8899)
17:44:14.963 [DEBUG] [.o.b.m.internal.MilightBinding:350 ] - milight: sendDecrease
17:44:14.963 [DEBUG] [.o.b.m.internal.MilightBinding:383 ] - milight: Bulb ‘3’ getting decreased to '36’
17:44:14.963 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '34:00:55’
17:44:14.964 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet ‘34:00:55’ to bridge ‘bridge1’ (192.168.8.11:8899)
17:44:15.064 [DEBUG] [.o.b.m.internal.MilightBinding:350 ] - milight: sendDecrease
17:44:15.064 [DEBUG] [.o.b.m.internal.MilightBinding:383 ] - milight: Bulb ‘3’ getting decreased to '27’
17:44:15.065 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '34:00:55’
17:44:15.065 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet ‘34:00:55’ to bridge ‘bridge1’ (192.168.8.11:8899)
17:44:15.165 [DEBUG] [.o.b.m.internal.MilightBinding:350 ] - milight: sendDecrease
17:44:15.166 [DEBUG] [.o.b.m.internal.MilightBinding:383 ] - milight: Bulb ‘3’ getting decreased to '18’
17:44:15.166 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '34:00:55’
17:44:15.166 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet ‘34:00:55’ to bridge ‘bridge1’ (192.168.8.11:8899)
17:44:15.267 [DEBUG] [.o.b.m.internal.MilightBinding:350 ] - milight: sendDecrease
17:44:15.267 [DEBUG] [.o.b.m.internal.MilightBinding:383 ] - milight: Bulb ‘3’ getting decreased to '9’
17:44:15.267 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '34:00:55’
17:44:15.268 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet ‘34:00:55’ to bridge ‘bridge1’ (192.168.8.11:8899)
17:44:15.368 [DEBUG] [.o.b.m.internal.MilightBinding:786 ] - milight: messageBytes to transform: '3A:00:55’
17:44:15.369 [DEBUG] [.o.b.m.internal.MilightBinding:778 ] - Sent packet ‘3A:00:55’ to bridge ‘bridge1’ (192.168.8.11:8899)
