I write this hopefully to help someone else but mostly so I have somewhere to store it ![]()
I have for a while now had a clunky setup with MiLight and rules and getting them to work. Today, in a hungover state I spent some time cleaning this up.
This relies on the excellent gateway provided by Chris Mullins
I have items for each group.
I use transforms to change the mode and brightness
I have a rule to change the colour (WIP to a transform if I can)
Group:Dimmer g_Wetroom_Dimmer "Wetroom Dimmer"
Group:Color g_Wetroom_Color "Wetroom Color"
Color MiLight_Item_Color_Group_1 "Wetroom Shower - Color" <colorlight> (g_Wetroom_Color)
Color MiLight_Item_Color_Group_2 "Wetroom Main - Color" <colorlight> (g_Wetroom_Color)
Color MiLight_Item_Color_Group_3 "Bathroom Main - Color" <colorlight>
Color MiLight_Item_Color_Group_4 "Spare - Color" <colorlight>
Dimmer MiLight_Item_Dimmer_Group_1 "Wetroom Shower - Dimmer" <light> (g_Wetroom_Dimmer) {mqtt=">[mqtt:home/lights/0x9B55/RGBW/1:command:*:JS(milight.dimmer.map.js)]"}
Dimmer MiLight_Item_Dimmer_Group_2 "Wetroom Main - Dimmer" <light> (g_Wetroom_Dimmer) {mqtt=">[mqtt:home/lights/0x9B55/RGBW/2:command:*:JS(milight.dimmer.map.js)]"}
Dimmer MiLight_Item_Dimmer_Group_3 "Bathroom Main - Dimmer" <light> {mqtt=">[mqtt:home/lights/0x9B55/RGBW/3:command:*:JS(milight.dimmer.map.js)]"}
Dimmer MiLight_Item_Dimmer_Group_4 "Spare - Dimmer" <light> {mqtt=">[mqtt:home/lights/0x9B55/RGBW/4:command:*:JS(milight.dimmer.map.js)]"}
String MiLight_Item_Mode_Group_1 "Wetroom Shower - Mode" {mqtt=">[mqtt:home/lights/0x9B55/RGBW/1:command:*:MAP(milights.map)]"}
String MiLight_Item_Mode_Group_2 "Wetroom Main - Mode" {mqtt=">[mqtt:home/lights/0x9B55/RGBW/2:command:*:MAP(milights.map)]"}
String MiLight_Item_Mode_Group_3 "Bathroom Main - Mode" {mqtt=">[mqtt:home/lights/0x9B55/RGBW/3:command:*:MAP(milights.map)]"}
String MiLight_Item_Mode_Group_4 "Spare - Mode" {mqtt=">[mqtt:home/lights/0x9B55/RGBW/4:command:*:MAP(milights.map)]"}
Colour Rules. Hoping to refactor this into a transform.
import org.eclipse.xtext.xbase.lib.Functions
val Functions$Function3 sendColor = [
GenericItem item,
String controller,
String group
var light = (item.state as HSBType)
var RGBRed = (light.red * 2.55 as int).toString("%.3f")
var RGBGreen = (light.green * 2.55 as int).toString.toString("%.3f")
var RGBBlue = (light.blue * 2.55 as int).toString.toString("%.3f")
var Brightness = (light.brightness * 2.55 as int).toString.toString("%.3f")
val packet = "{\"brightness\":" + Brightness + ",\"bulb_mode\":\"color\",\"color\":{\"r\":" + RGBRed + ",\"g\":" + RGBGreen + ",\"b\":" + RGBBlue + "}}"
publish("mqtt","home/lights/" + controller + "/RGBW/" + group, packet)
rule "milight group 1"
Item MiLight_Item_Color_Group_1 received command
sendColor.apply(MiLight_Item_Color_Group_1, "0x9B55", "1")
rule "milight group 2"
Item MiLight_Item_Color_Group_2 received command
sendColor.apply(MiLight_Item_Color_Group_2, "0x9B55", "2")
rule "milight group 3"
Item MiLight_Item_Color_Group_3 received command
sendColor.apply(MiLight_Item_Color_Group_3, "0x9B55", "3")
rule "milight color group 4"
Item MiLight_Item_Color_Group_4 received command
sendColor.apply(MiLight_Item_Color_Group_4, "0x9B55", "4")
milight.dimmer.map.js (Don’t forget you need to install the JS transform from the paper UI.
(function(i) {
var retVal = 0
if (input == "ON"){
retVal = 255
else if (input == "OFF"){
retVal = 0
else if(input >= 0)
retVal = input / 100 * 255;
else
retVal = 0;
return "{\"brightness\":\"" + Math.floor(retVal) + "\"}"
})(input)
milight.map. This is for the various modes.
1={"status":"ON"}
0={"status":"OFF"}
SET_WHITE_MODE={"command":"set_white"}
SET_NIGHT_MODE={"command":"night_mode"}
SET_RGB_MODE={"command":"color"}
SET_SCENE_MODE={"command":"scene"}
SET_DISCO_MODE={"mode":"8"}
SET_FLASH_MODE={"mode":"3"}
The above replaces reams and reams of rules and lambdas which really killed the RPi 3 I am running this on. Doing anything to them was very slow and caused people to doubt the click and go clicky-click-click which helped nothing…
While I post it here in the hopes that it helps someone else, I would appreciate feedback in how I might make it simpler.
thanks.
Crispin
