events.log:
2017-12-26 09:13:39.761 [me.event.ThingUpdatedEvent] - Thing ‘milight:bridgeV6:F0FE6B1E2692’ has been updated.
2017-12-26 09:13:40.181 [ome.event.ItemCommandEvent] - Item ‘Licht_Wohnzimmer_Esstisch_Weiss’ received command ON
2017-12-26 09:13:40.188 [vent.ItemStateChangedEvent] - Licht_Wohnzimmer_Esstisch_Weiss changed from OFF to ON
2017-12-26 09:13:40.908 [me.event.ThingUpdatedEvent] - Thing ‘milight:bridgeV6:F0FE6B1E2692’ has been updated.
2017-12-26 09:13:41.656 [me.event.ThingUpdatedEvent] - Thing ‘milight:bridgeV6:F0FE6B1E2692’ has been updated.
2017-12-26 09:13:43.322 [me.event.ThingUpdatedEvent] - Thing ‘milight:bridgeV6:F0FE6B1E2692’ has been updated.
2017-12-26 09:13:43.324 [me.event.ThingUpdatedEvent] - Thing ‘milight:bridgeV6:F0FE6B1E2692’ has been updated.
openhab.log:
Doesn’t show any related infos.
The action Licht_Wohnzimmer_Esstisch_Weiss doesn’t do anything. Other Actions are working. The problem is with different hardware (RGBW and RGBWW). What can I do?
I have the same problem since I updated to 2.2. The LED temperature isn’t working either.
You can go back to white selecting it from the color picker.
Regards.
Hi @David_Graff,
Are you still mantaining this binding? OH 2.2 update has broken it. I have a V3-V5 bridge and since I updated, color temperature, night mode, animation mode and animation speed don’t work.
Regards.
I am using OH 2.2 with V6 bridge and I have the same problem with white, I can use the colorpicker to set a low saturation but that only uses the color mix to represent white it doesn’t actually switch to using the white LEDs, obviously the color temperature wont change because that effects the white LEDs.not the color mix.
Search this forum for espmilighthub binding, I wrote this for a new open source hub that controls milight globes. All those things u say is broken is working fine in my binding.
I found an odd solution to this problem. Use ledtemperature instead of ledwhitemode as a switch in Items. Then, use a single mapping for ON in sitemaps (i.e. mappings=[ON=“White”]). Actually, any mapping works strangely… Also make sure autoupdate is set to false in items so that it functions as a push button and not as a switch.
Thanks for the suggestion. Using ledtemperature instead of ledwhitemode works for rgbwwLed items (yeah!), but it doesn’t work for rgbwLed items as far as I can see.
