Hi All,
I’ve just setup openhab on Ubuntu following the apt-get install guide.
I’ve added the milight pairing and read the wiki entry on how to setup milight. The bridge is configured as “bridge1”.
My items looks like (I’ve omitted the groups):
Switch Light_Livingroom_All (Lights, Lounge) {milight=“bridge1;6”} #Switch to turn all RGBW Bulbs on/off
Switch Light_Livingroom_TV (Lights, Lounge) {milight=“bridge1;7”} #Switch for RGBW channel 1
Switch Light_Livingroom_Sofa (Lights, Lounge) {milight=“bridge1;9”} #Switch for RGBW channel 3
Which from what I can tell is correct.
The “all” switch works but the others do not. I click them an no action takes place.
I’ve turned on debugging level logging in the logback.xml and all I can see the following error;
Received command ‘TOGGLE’ for item ‘Light_Livingroom_TV’, but the item does not exist in the registry
My sitemap currently looks like;
sitemap default label=“Home”
Frame {
Group item=Lounge label=“Lounge” icon=“groundfloor”
Switch item=Light_Livingroom_All label=“All Lounge Lights”
Switch item=Light_Livingroom_TV label=“TV Lamp”
Switch item=Light_Livingroom_Sofa label=“Sofa Lamp”
Am I missing something here in my setup that is causing this not to work?
Additionally the only item that actually shows in the group is the “All” switch.
Thanks!
