Mill LAN Binding [4.1.0.0;6.0.0.0)
This binding integrates generation 3 Mill devices using the local network only.
Documentation can be found here.
This binding has so far only been tested with Mill panel heaters. If you have access to generation 3 Mill devices of a different type and would like to help me verify that they work as intended, please open a GitHub issue or tag me in a forum topic.
Changelog
Version 1.0.1
Added
  • Create dedicated decimal precision handling and improve decimal value comparison to avoid triggering events when no real change has taken place.
  • Create channel for “Independent Device mode” set-temperature that combines different API endpoints to simulate a “real” channel.
Fixed
  • Minor improvements to documentation.
  • Minor improvements to Norwegian translations.
  • Discovery support for more recent panel heater firmware.
Version 1.0.0
  • initial release
Resources
https://github.com/Nadahar/Mill-LAN-openHAB-Binding/releases/download/v1.0.0/org.openhab.binding.milllan-1.0.0.jar
https://github.com/Nadahar/Mill-LAN-openHAB-Binding/releases/download/v1.0.1/org.openhab.binding.milllan-1.0.1.jar
