That device has been in the database since 2.5.6. Without (unfiltered) debug logs, as mentioned in the binding documentation only your system knows what the issue is.
The version in the database is limited to version 4. This might be on purpose, or it might just be that the person entering the data was a bit too keen
Can you check you manual to see if the configuration parameters etc looks the same as the one in the database. If so, we an change the versions - otherwise it will need a new entry/
