Here is my logging:
openhab> log:list
Logger | Level
ROOT | WARN
javax.jmdns | ERROR
org.eclipse.smarthome | INFO
org.jupnp | ERROR
org.openhab | INFO
org.openhab.binding.mios | DEBUG
org.ops4j.pax.web.service.jetty.internal.JettyServerWrapper | ERROR
smarthome.event | INFO
smarthome.event.InboxUpdatedEvent | ERROR
smarthome.event.ItemStateEvent | ERROR
smarthome.event.ThingStatusInfoEvent | ERROR
Here is the output in the log with debug logging:
2016-10-10 08:56:24.709 [DEBUG] [ab.binding.mios.internal.MiosBinding] - internalReceiveCommand: itemName ‘CT100_SETPOINT_HEAT’, command '69.0’
2016-10-10 08:56:24.710 [DEBUG] [ding.mios.internal.MiosUnitConnector] - callDevice: Need to remote-invoke Device ‘unit:house,device:3/service/urn:upnp-org:serviceId:TemperatureSetpoint1_Heat/CurrentSetpoint’ action ‘69.0’ and current state ‘70’)
2016-10-10 08:56:24.712 [ERROR] [ab.binding.mios.internal.MiosBinding] - Error handling command
org.openhab.core.transform.TransformationException: An error occured while opening file.
at org.openhab.core.transform.TransformationHelper$TransformationServiceDelegate.transform(TransformationHelper.java:63)[196:org.openhab.core.compat1x:2.0.0.201610072017]
at org.openhab.binding.mios.internal.config.DeviceBindingConfig.transformCommand(DeviceBindingConfig.java:442)[195:org.openhab.binding.mios:1.9.0.201610070111]
at org.openhab.binding.mios.internal.MiosUnitConnector.callDevice(MiosUnitConnector.java:192)[195:org.openhab.binding.mios:1.9.0.201610070111]
at org.openhab.binding.mios.internal.MiosUnitConnector.invokeCommand(MiosUnitConnector.java:378)[195:org.openhab.binding.mios:1.9.0.201610070111]
at org.openhab.binding.mios.internal.MiosBinding.internalReceiveCommand(MiosBinding.java:271)[195:org.openhab.binding.mios:1.9.0.201610070111]
at org.openhab.core.binding.AbstractBinding.receiveCommand(AbstractBinding.java:97)[196:org.openhab.core.compat1x:2.0.0.201610072017]
at org.openhab.core.events.AbstractEventSubscriber.handleEvent(AbstractEventSubscriber.java:42)[196:org.openhab.core.compat1x:2.0.0.201610072017]
at org.apache.felix.eventadmin.impl.handler.EventHandlerProxy.sendEvent(EventHandlerProxy.java:415)[3:org.apache.karaf.services.eventadmin:4.0.4]
at org.apache.felix.eventadmin.impl.tasks.HandlerTask.run(HandlerTask.java:90)[3:org.apache.karaf.services.eventadmin:4.0.4]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_91]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_91]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_91]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_91]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_91]
Here is the transformation files that I have:
readme.txt
en.map
de.map
miosZWaveStatusIn.map
miosWeatherConditionGroupIn.map
miosUnSwitchIn.map
miosUPnPTransportStatePlayModeCommand.map
miosUPnPRenderingControlVolumeCommand.map
miosUPnPRenderingControlMuteCommand.map
miosTStatSetpointHeatCommand.map
miosTStatSetpointCoolCommand.map
miosTStatModeStatusCommand.map
miosTStatFanOperatingModeCommand.map
miosSwitchOut.map
miosSwitchIn.map
miosStatusIn.map
miosShutterCommand.map
miosSceneActiveIn.map
miosMSwitch8.map
miosMSwitch7.map
miosMSwitch6.map
miosMSwitch5.map
miosMSwitch4.map
miosMSwitch3.map
miosMSwitch2.map
miosMSwitch1.map
miosLockCommand.map
miosDimmerCommand.map
miosDeviceStatusUI.map
miosContactOut.map
miosContactIn.map
miosArmedCommand.map
