I’ve just connected a GoControl GC-TBZ48 thermostat to my Z-wave system. Using it through the Vega Edge hub works fine, however when I try to remotely control the Mode of the thermostat via the MiOS binding I can only successfully turn the mode to “Off” every other mode request results in the error:the wrong format.
2018-07-14 21:15:47.901 [ERROR] [ding.mios.internal.MiosUnitConnector] - callDevice: The parameter is in the wrong format. BindingConfig 'unit:veraedge,device:12/service/urn:upnp-org:serviceId:HVAC_UserOperatingMode1/ModeStatus,command:Heat=HVAC_UserOperatingMode1/SetModeTarget(NewModeTarget=HeatOn)', UPnP Action 'HeatOn'
Here are two item configurations that I can alternatively comment
String downstairsThermostatModeStatus "Mode Status" (GDevices,GRoom2) {mios="unit:veraedge,device:12/service/HVAC_UserOperatingMode1/ModeStatus,command:Off=HVAC_UserOperatingMode1/SetModeTarget(NewModeTarget=Off)"} // This one works fine
String downstairsThermostatModeStatus "Mode Status" (GDevices,GRoom2) {mios="unit:veraedge,device:12/service/HVAC_UserOperatingMode1/ModeStatus,command:Heat=HVAC_UserOperatingMode1/SetModeTarget(NewModeTarget=HeatOn)"} // This one gives the parameter is in the wrong format error
My sitemap file has
Switch item=downstairsThermostatModeStatus mappings=[HeatOn="Heat", CoolOn="Cool", AutoChangeOver="Auto", Off="Off"]
The fact that it seems to work fine for Off but not any other modes suggest there is something I’m missing in the code. I’ve tried several variations of HeatOn, heaton, 1, heat but no dice I’ve also tried the default mapping file provided with the binding that doesn’t work either. Any suggestions?
phil
