Trying to add a new zwave device of a different type. I pulled down the Mios Item Generator scripts again and ran them.
It seems as though maybe a new release of UI7 has removed the http://${MIOS_IP}:49451/data_request?id=user_data&output_format=xml function?
I can go to http://${MIOS_IP}:49451/ and it redirects to http://${MIOS_IP}:49451/cmh but the other link returns 404 not found but it isn’t a browser 404, it’s clearly a 404 from the vera.
@guessed Do you maintain this? Sorry to call you out. I was able to nail up some of the items using examples I found but I still cannot get the generator to work and would like to see other item types available.
I just had the same issue - looks like miosLoad.sh makes the request to port 49451 on the Vera, but http://wiki.micasaverde.com/index.php/Luup_Requests examples seem to use port 3480. Changing the port number in the curl request worked for me.
