I have a somfy zrtsi device to control my awning. It is connected to my mios zwave network with a vera edge. I can control the awning fine with the Vera interface.
In openhab I am able to send the open and close commands to the awning, but I have not figured out a way to send the “stop” command so that I can interrupt the current action and the awning stays in that posiiton.
Here is what the mios binding tools generated:
/* Device - Awning1 */
Number Awning1Id “ID [%d]” (GDevices) {mios=“unit:house,device:248/id”}
String Awning1DeviceStatus “Awning1 Device Status [MAP(miosDeviceStatusUI.map):%s]” (GDevices) {mios=“unit:house,device:248/status”}
Number Awning1Configured “Awning1 Configured [%d]” (GDevices,GRoom11) {mios=“unit:house,device:248/service/HaDevice1/Configured”}
DateTime Awning1LastUpdate “Awning1 Last Update [%1$ta, %1$tm/%1$te %1$tR]” (GDevices,GRoom11) {mios=“unit:house,device:248/service/HaDevice1/LastUpdate”}
DateTime Awning1FirstConfigured “Awning1 First Configured [%1$ta, %1$tm/%1$te %1$tR]” (GDevices,GRoom11) {mios=“unit:house,device:248/service/HaDevice1/FirstConfigured”}
String Awning1Target “Awning1 Target [%s]” (GDevices,GRoom11) {mios=“unit:house,device:248/service/urn:upnp-org:serviceId:WindowCovering1/Target”}
Dimmer Awning1LoadLevelTarget “Awning1 Load Level Target [%d %%]” (GDevices,GRoom11) {mios=“unit:house,device:248/service/Dimming1/LoadLevelTarget”}
Dimmer Awning1LoadLevelStatus “Awning1 Load Level Status [%d %%]” (GDevices,GRoom11) {mios=“unit:house,device:248/service/Dimming1/LoadLevelStatus”}
Switch Awning1Status “Awning1 Status” (GDevices,GRoom11) {mios=“unit:house,device:248/service/SwitchPower1/Status”}
I have the following in my sitemap:
Switch item=Awning1LoadLevelStatus icon=“none” label=“Awning” mappings=[“0”=“Open”, “1”=“Close”, “2”=“Stop”]
Open and Close work fine, but I have no idea what value to use for Stop. Stop works just fine in the Vera interface, but when I perform a stop in the Vera Interface all I see in the openhab logs is:
2016-06-23 12:05:38 - Awning1DeviceStatus state updated to PENDING
2016-06-23 12:05:38 - Awning1DeviceStatus state updated to SUCCESS
