The double quote (") in the mid of your REGEX seems to be wrong. It marks the end of the string. In case you require one I think it needs to be escaped.
Thanks for responding, I tried removing the (") and it still worked in my regex tester, so I guess it may not be needed, however now I get:
2021-08-23 16:34:50.675 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'http.things' has errors, therefore ignoring it: [10,80]: Character n is neither a decimal digit number, decimal point, nor "e" notation exponential mark.
[10,57]: mismatched character '/' expecting set null
[10,83]: mismatched input ':' expecting ']'
[10,84]: missing '}' at 'value'
[10,91]: mismatched character '<EOF>' expecting '"'
