Missing: A binding for Discovergy Smart Meters! :-)
It supports whatever electricity meters discovergy decides to use. There are a few different types as far as I know, I don’t know which ones though.
Okay..
Hi Flole,
do you offer a download for your binding?
I would really like to use it.
Regards,
Holger
Hi Holger,
I still can’t publish it as the license of the examples and their libraries still hasn’t been clarified by discovergy. Feel free to contact them and ask for clarification (I didn’t get an answer when I did that), once that is done I might be able to release it (depending on their license).
Kind regards
Flole
Hallo Flole,
I just wrote an e-Mail to Discovergy to get clarity concerning the legal issues. I pointed to this thread and asked for a reply.
Regards,
Holger
Hi @Holger_Richter,
I assume you never got a response?
Kind regards
Flole
Hi Flole,
I asked “discovergy” 3 times and they told me my request would still be processed. But I will not give up.
Regards,
Holger
I asked them in the official forum again a few days ago. Unfortunately I lost the source code of my binding. While I still have the sources.jar it all needs to be put together so it builds again. So even if they clarify the license there will only be a jar-file based addon and a bunch of source files, I won’t go through the “putting everything back together”, especially since this is not in a state that would have a chance of getting it merged as the guidelines have changed.
… and just a few hours after my post they clarified the license in the Forum and are also considering adding a license file. I’ll publish my binding as a jar file tomorrow, I think this clarification is sufficient to not get sued :wink:
I have uploaded the binding now, you can grab a copy here. (For openHAB 2.x) The 3.x binding is further down this page.
Please let me know if you find any issues.
Hi Flole,
I have just seen your last post. Great! Thanks alot for the binding. Thumbs up!
Works great !
Holger
Hi Flole,
could you please upgrade your binding to openhab 3.0?
As I no longer have the source code that’s not possible. But I think a 2.x binding should also work on 3.0, did you try that?
No it will not work. The namespace of the core classes has changed.
Hi Flole,
that’s really bad luck. I just upgraded to Openhab 3 and I am again without a working Discovergy - binding.
As former FHEM-user my quick-fix (just took minutes) is just using the FHEM module and sending the data via MQTT through FHEM’s “generic_mqtt” -bridge. I am using this workaround also for a missing Oilfox - binding. Just in case others are having the same problem.
Regards,
Holger
I still haven’t updated to 3.0 myself as I had to migrate all my mqtt items to the new binding (those were more than 600 items, and the migration task is time consuming and I had to stop quite often because I just couldn’t focus anymore). Anyways, that is now almost done and I will need to take care of migrating other bindings including the Discovergy one. I had a brief look at the jar and it looks like I should be able to get the most important stuff back from the jar file so the migration should be mostly copying stuff from the old binding.
Thats the good news, the bad news is that I don’t have a lot of time at the moment, so this could very well take another 2 or 3 (or maybe even 4) months. I am very unhappy about that situation myself as my migration to 3.0 should have been done for quite a while now but still isn’t.
Hi @Holger_Richter (and others who want to use this binding on 3.0),
fortunately my migration tasks for 3.0 went faster than expected and I was able to make a build of the Discovergy Binding for 3.0 (or 3.1 to be more precise, but it should work on 3.0 aswell) already today. It is entirely untested, so I have absolutely no idea if it will work or not, I will hopefully finish my migration to 3.0 this week, and then I will also test this binding.
Anyways, as I know that some of you really want this binding and a binding with issues is better than no binding you can already grab a copy here (and please tell me if something doesn’t work so I can fix it before I encounter the issue myself :wink: ).
Also: Maybe someone can update the title as the binding is no longer missing :wink:
Really hope that this helps
Flole
Hallo Flole,
thanks for beeing that fast with the new openhab 3 binding. Unluckily it’s not working:
Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.discovergy-3.1.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.discovergy [281]
Unresolved requirement: Import-Package: com.github.scribejava.core.builder; version=“[6.9.0,7.0.0)”
Regards
Holger
I’ve updated the binding, now it should at least start up properly. Link is still the same.
Works great! Thank’s again, Flole!
