[Tried to find different ways to add the end points to existing binding or change lock name to be YRL220 as it does includes the endpoints and is just different hardware. My skill level is not at the level of recreating a binding]
The short answer is to register (if not done already) and open a ticket to get write access and make the changes. Mark the device for review and in a couple of days it will be in the latest zwave snapshot here.
I’m not sure what Alarm_raw is going to do (or what it does on the other lock) since it is not one of the supported types, (by my read- but I’m not an expert on this)
Bob
edit:
I found where the Alarm_raw was handled, so it should work like the other device once you update the database.
Is your lock included securely? If it wasn’t included securely you might get strange behavior. If it is not included securely, you would need to exclude, factory reset the lock, and re-include. And you have to have your Zwave stick in the controller when you do this - if you have a portable Zwave stick, it won’t include securely if it is not in the controller. Ignore all this if it has been securely included. This is just a guess.
