Missing gridPower in EVCC Installation
Hey, after an Update of EVCC from 0.12x.x to 0.20x.x i realized, that the value for gridpower is always NULL. Then i deleted the “EVCC Installation” thing and created it again. After that, the channel gridpower disappeared from “EVCC Installation”.
I also tried to uninstall and install again the EVCC binding, but with the same result.
Does anyone have the same problem or is it a problem only i have?
My setup
openHAB 4.3.3
evcc binding 4.3.3
evcc 0.201.1
I have the same setup. No gridpower in the binding. With mqtt it is evcc/site/grid/power.
Hello, I have the same setup. After update to evcc 0.201.1 also grid power is NULL.
Check the configuration settings in your EVCC installation to ensure everything is set up correctly and try looking at the logs for any errors related to grid power.
EVCC shows a value for grid power. EVCC has no FATAL, ERROR, WARNINGs, etc. So i think EVCC is working correctly.
Today i updated my Openhabian. Now the channel gridpower is back. After i linked all channels, the value for gridpower is now shown again in my widget.
My setup now:
openHAB 4.3.4
evcc binding 4.3.4
evcc 0.203.1
