Thank you but this is not helpful. My FS20 switches working fine but the HMS100TFK is some kind like HMS100TF.
This is the openHAB log:
20:13:03.488 [DEBUG] [o.o.i.t.c.i.AbstractCULHandler:239 ] - Received raw message from CUL: H29EF040000002E
20:13:03.498 [INFO ] [inding.hms.internal.HMSBinding:119 ] - device: 29EF, T: 0.0, H: 0.0, Bat.: ok
20:13:03.507 [DEBUG] [o.o.i.t.c.i.AbstractCULHandler:296 ] - Requesting credit report
20:13:03.539 [DEBUG] [o.o.i.t.c.i.AbstractCULHandler:239 ] - Received raw message from CUL: 21 900
20:13:03.549 [DEBUG] [o.o.i.t.c.i.AbstractCULHandler:278 ] - credit10ms = 900
20:13:10.989 [DEBUG] [o.o.i.t.c.i.AbstractCULHandler:239 ] - Received raw message from CUL: H29EF040100002F
20:13:11.000 [INFO ] [inding.hms.internal.HMSBinding:119 ] - device: 29EF, T: 0.1, H: 0.0, Bat.: ok
20:13:11.010 [DEBUG] [o.o.i.t.c.i.AbstractCULHandler:296 ] - Requesting credit report
20:13:11.041 [DEBUG] [o.o.i.t.c.i.AbstractCULHandler:239 ] - Received raw message from CUL: 21 900
20:13:11.051 [DEBUG] [o.o.i.t.c.i.AbstractCULHandler:278 ] - credit10ms = 900
openHAB bindings are interpreting the HMS100TFK wrong. There are no temperature or humidity sensors in this device, its just a contact and my old log in FHEM says “Switch Detect: off” or “Switch Detect: on”.
Is there a way to get the real values what is HMS100TFK sending?
