Missing serial devices on drop-down serlial list for Modbus Serial Slave configuration (Paper UI)
Hi All,
is there any way to add additional device files to the Serial Port drop-down list (Modbus Biding configuration)?
I created SYMLINKS to /dev/ttyUSB0, /dev/ttyUSB1, … files
Symlinks:
/dev/rs485_1
/dev/onewire_1
How make the symlinks devices available on drop-down list?
I know that I can setup this manually in modbus.cfg file, but I would like to know if this is possible via Paper UI interface.
Thank you in advance for replays
Not other than following the documentation and modifying EXTRA_JAVA_OPTS.
If you use this tutorial How to make symlinks for usb ports in linux (EXTRA_JAVA_OPTS) they are visible in the drop-down list in paper ui.
Thank you both of you.
I set EXTRA_JAVA_OPTS="-Dgnu.io.rxtx.SerialPorts=/dev/rs485_1" and issue is solved.
Thank you.
