getting errors. I think it started after installing one of the latest snapshots. Currently i’m on openHAB 2.4.0 Build #1364
2018-09-16 23:05:03.295 [ERROR] [org.jupnp.transport.spi.StreamClient] - Request: HttpRequest[GET /capability HTTP/1.1]@7c95d877 failed
java.lang.NullPointerException: Missing SslContextFactory
at java.util.Objects.requireNonNull(Objects.java:228) ~[?:?]
at org.eclipse.jetty.io.ssl.SslClientConnectionFactory.<init>(SslClientConnectionFactory.java:50) ~[74:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.client.HttpClient.newSslClientConnectionFactory(HttpClient.java:1155) ~[70:org.eclipse.jetty.client:9.4.11.v20180605]
at org.eclipse.jetty.client.HttpDestination.newSslClientConnectionFactory(HttpDestination.java:138) ~[70:org.eclipse.jetty.client:9.4.11.v20180605]
at org.eclipse.jetty.client.HttpDestination.<init>(HttpDestination.java:95) ~[70:org.eclipse.jetty.client:9.4.11.v20180605]
at org.eclipse.jetty.client.PoolingHttpDestination.<init>(PoolingHttpDestination.java:25) ~[70:org.eclipse.jetty.client:9.4.11.v20180605]
at org.eclipse.jetty.client.http.HttpDestinationOverHTTP.<init>(HttpDestinationOverHTTP.java:32) ~[70:org.eclipse.jetty.client:9.4.11.v20180605]
at org.eclipse.jetty.client.http.HttpClientTransportOverHTTP.newHttpDestination(HttpClientTransportOverHTTP.java:51) ~[70:org.eclipse.jetty.client:9.4.11.v20180605]
at org.eclipse.jetty.client.HttpClient.destinationFor(HttpClient.java:539) ~[70:org.eclipse.jetty.client:9.4.11.v20180605]
at org.eclipse.jetty.client.HttpClient.send(HttpClient.java:572) ~[70:org.eclipse.jetty.client:9.4.11.v20180605]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:727) ~[70:org.eclipse.jetty.client:9.4.11.v20180605]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:680) ~[70:org.eclipse.jetty.client:9.4.11.v20180605]
at org.jupnp.transport.impl.jetty.JettyStreamClientImpl$1.call(JettyStreamClientImpl.java:149) [210:org.jupnp:2.4.0]
at org.jupnp.transport.impl.jetty.JettyStreamClientImpl$1.call(JettyStreamClientImpl.java:1) [210:org.jupnp:2.4.0]
This error message appears when UPNP is scanning my Samsung appliances, I think it’s related to SSL cert on appliance.
I am getting the same repeated messages in the log with the latest update, just updated via apt a few hours ago.
2018-09-19 22:11:39.514 [ERROR] [org.jupnp.transport.spi.StreamClient] - Request: HttpRequest[GET /capability HTTP/1.1]@3e26e79e failed
at org.jupnp.transport.impl.jetty.JettyStreamClientImpl$1.call(JettyStreamClientImpl.java:149) [215:org.jupnp:2.4.0]
at org.jupnp.transport.impl.jetty.JettyStreamClientImpl$1.call(JettyStreamClientImpl.java:1) [215:org.jupnp:2.4.0]
@wborn could this be related to the karaf update as suggested? I am not seeing any bad behavior, as far as I can tell all of my items/things are working, but it fills up the log.
The startup behavior could have changed with the Karaf upgrade. The bad behavior will probably be that the UPnP discovery no longer works. @Kai do you know how to solve these NPEs with jupnp?
I haven’t yet encountered this error myself, I just tested it with build #1369 and UPnP works nicely here.
I don’t really think that the Karaf upgrade is related - maybe indirectly due to the Jetty upgrade.
Is anyone able to reproduce it easily with a clean fresh installation of the zip and the demo package?
Just had a look at the code. It seems that you have some UPnP device that asks for https for querying its services - and jUPnP simply isn’t prepared for this.
I would claim that the exception goes away, if you remove the specific device from your network. I would be interested in what device this is.
Can you really confirm that UPnP worked with that device in the network in previous openHAB builds? Then something must have changed in Jetty…
Hello @Kai, as I mentioned: This error message appears when UPNP is scanning my Samsung appliances, I think it’s related to SSL cert on appliance. Do you need more details? I can turn on debug and take couple screenshots.
Ah, thanks, I had missed the Samsung part of your message above.
Can you confirm that there wasn’t a problem with earlier snapshots? From the code, it looks to me as if SSL with UPnP could never have worked so far…
There is a chance that you are right I clearly remember that I’ve never seen such errors util I installed latest release some time in August.
What is actually UPnP doing for OpenHAB? How can I see that it’s working for non-SSL devices?
By successfully discovering such devices. Could be e.g. a Philips hue bridge, which announces itself through (non-ssl) UPnP.
I have entered https://github.com/jupnp/jupnp/issues/109 for tracking this issue.
It would be nice if you could post some trace logging on that issue from your device. Simply enable
log:set TRACE org.jupnp.transport.impl.jetty
and find the log excerpt just before the exceptions appears.
I’m seeing this pretty frequently in OH3 build 1963. I’ll try to capture some relevant debug logs.
2020-10-08 22:27:09.090 [ERROR] [org.jupnp.transport.spi.StreamClient] - Request: HttpRequest[GET /capability HTTP/1.1]@6ecd1c12 failed
at java.util.Objects.requireNonNull(Objects.java:246) ~[?:?]
at org.eclipse.jetty.io.ssl.SslClientConnectionFactory.<init>(SslClientConnectionFactory.java:54) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpClient.newSslClientConnectionFactory(HttpClient.java:1175) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpDestination.newSslClientConnectionFactory(HttpDestination.java:137) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpDestination.<init>(HttpDestination.java:94) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.PoolingHttpDestination.<init>(PoolingHttpDestination.java:25) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.http.HttpDestinationOverHTTP.<init>(HttpDestinationOverHTTP.java:32) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.http.HttpClientTransportOverHTTP.newHttpDestination(HttpClientTransportOverHTTP.java:51) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpClient.destinationFor(HttpClient.java:546) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpClient.send(HttpClient.java:579) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:728) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:681) ~[bundleFile:9.4.20.v20190813]
at org.jupnp.transport.impl.jetty.JettyStreamClientImpl$1.call(JettyStreamClientImpl.java:155) [bundleFile:?]
at org.jupnp.transport.impl.jetty.JettyStreamClientImpl$1.call(JettyStreamClientImpl.java:1) [bundleFile:?]
at org.jupnp.transport.spi.AbstractStreamClient$RequestWrapper.call(AbstractStreamClient.java:204) [bundleFile:?]
at org.jupnp.transport.spi.AbstractStreamClient$RequestWrapper.call(AbstractStreamClient.java:1) [bundleFile:?]
at java.lang.Thread.run(Thread.java:834) [?:?]```
