MiyoCube Binding for openHAB
This binding integrates the Miyo Smart Irrigation System with openHAB. The Miyo Cube acts as a central gateway for your Miyo sensors and valves, enabling smart, automated irrigation for your garden.
This is currently a beta release for testing purpose. In the future it may be submitted to the official OpenHAB bindings.
Features:
Connects to your local Miyo Cube via WebSocket and HTTP.
Supports automatic discovery of all sensors, valves, and circuits connected to your Cube.
Exposes all relevant sensor data (moisture, temperature, brightness, solar voltage, etc.) as openHAB channels.
Allows control of irrigation circuits and valves directly from openHAB.
Supports both read and write channels for automation and manual control.
Provides status and diagnostic information for all connected devices.
Requirements:
A working Miyo Cube on your local network.
The API key is automatically retrieved during initial setup (press the hardware button on the Cube to enable link mode).
First set up the Cube Bridge and then do a scan to retrieve all connected devices automatically.
Changelog
Version 1.1.0
- Changed dual valves from one valve with two valve states to two separate valves for correct circuit assignment. It’s recommended to re-scan the valves.
- Fixed channel label translations.
Version 1.0.0
- initial release
