Mmdev: A JSR223 library for defining all your items and rules in Jython
Preface
I’ve had a few people ask me at various times for a copy of my OpenHAB configuration. I’ve taken some time to clean up the code a bit, and I think I’m finally ready to release it.
This library contains an updated version of Ivan’s Helper Libraries. It will not function with the original library. I have tried to maintain backwards compatibility with the original library.
I haven’t maintained the unit tests, code typing, or documentation. I plan to begin work on those soon.
The rest of this post is a copy of the basic usage document for mmdev from here. I will try to keep these in sync. This should be enough documentation to use the library for now, at least until the full code documentation is up to snuff.
mmdev
mmdev is a community library for openhab’s jsr223 jython extension. It
allows you to define your entire item and rule configuration in python, and is designed to have a simple to use interface. It generates and maintains the underlying items and rules automatically based on an object/event model that you define.
mmdev resembles an ORM to some extent. The primary goal of this library is to allow you to define behaviors between groups of items without having to use complex rule DSL logic. All logic is instead driven by standard python callback functions.
Here is a small example defining a fan that turns on when the weather temperature exceeds a certain value, but only while a power toggle is switched on. Additionally, the fan switch is exposed over google assistant via user-provided metadata:
from community.mmdev.device import as_device
from community.mmdev.manager import Manager
# Here we define the class definition for fan devices.
@as_device(ephemeral=True)
def Fan(device):
    # Define the properties/items driving this device class.
    energized = device.property(bool, 'Energized', default=False)
    monitor = device.property(bool, 'Monitor', default=False)
    powered = device.property(bool, 'Powered', default=False)
    setpoint = device.property(int, 'Setpoint', default=F
70, dimension='Temperature')
    # Here we define the behavior of this device, using property events.
    @monitor.on_change()
    @powered.on_change()
    def update():
        # This commands the item backing `energized`.
        energized.command = (
            # This retrieves the current value of the item backing `powered`,`monitor` and `setpoint` and translates them to native python typed values.
            powered.value and monitor.value > setpoint.value
    # This declares the list of properties we want publicly exposed.
    return {
        energized,
        monitor,
        powered,
        setpoint
# Create a device manager we can use to create device objects.
m = Manager()
# Create a free-floating temperature state property.
temperature = m.state_for(
    int, 'Temperature', default=70,
    channel='zwave:honeywell_th6320zw_00_000:controller:thermostat:sensor_temperature'
# Create a fan object, overriding the item for its monitor property and attaching the appropriate channel.
# Expose the energized channel over google assistant as a fan.
fan = m.device_for(
    device_class=Fan,
    device_name='Desk Fan',
    room_name='Study',
    energized_channel='tplinksmarthome:hs300:powerstrip_ac:outlet2#switch',
    monitor_proxy=temperature,
    energized_metadata={'ga': ('Fan', {
        "lang": "en",
        "roomHint" "Living Room",
        "name": "Living Room Fan"
# At this point, any time the temperature channel changes on the temperature state object, the fan device will toggle the outlet channel as needed.
Installation
To install mmdev, download this zip and copy the automation folder to the root of your openhab configuration folder.
mmdev comes with an extended, maintained version of Ivan’s Helper Libraries. I have attempted to remain as backwards compatible as possible, but I may have missed something. If my version of the helper libraries breaks existing scripts, please let me know.
mmdev will not work with other versions of the helper libraries.
Usage
Put user scripts in automation/jsr223/lib/python/personal.
Place extra community libraries in automation/jython/lib/community.
Object Modelling
OpenHAB has native to it the concept of items, indivual values that can be tied
to a channel. mmdev treats collections of these items as objects akin to real
world devices. For example, a fan device might have a power and speed item
associated with it that represents the power and speed of a real fan. mmdev refers to these objects as devices.
Devices are designed to allow you to declare a group of behaviors for a set of real world devices exactly once. You can then instantiate multiple devices using that declared behavior, generating items for each.
Devices are defined as python classes that describe the items they use and the
rules they have between them. mmdev refers to its equivalent of items as
device properties.
Devices have a room and a name associated with them. Two devices with the same
type, name, and room should not be created, as this could lead to erratic
behavior with the items backing the device properties.
Devices
Devices are represented by objects in python. Publicly available properties are
exposed as attributes on those objects.
A device property is used the same way both when defining a device class or
accessing the fields on a device object. They can be used to change or query
the state of an item or to create rules around that item.
Collections
Devices have an associated collection name and class name. Collections are
community modules defining a set of device classes that can be used with
mmdev. mmdev has a number of objects it provides out of the box in a
collection named Builtin.
The collection of a device can either be provided with the device definition, or it can be auto-detected.
Auto detection works as follows:
The grandparent of the current module is imported. If it imports successfully, and has a field ‘collection’ on it, that field is used. Otherwise, the name of the module is used as the collection. If the grandparent cannot be imported, it instead imports the parent and repeats the same process.
A device name is discovered based on the function name given during device definition.
Properties
Properties wrap a single item each. Once a property is defined, mmdev will
begin to maintain the item backing it transparently whenever a new device is instantiated..
Property Items
The underling item backing a property is auto-generated based on the name,
class_name, collection_name, and room_name of a device.
You can query the item name of a property’s item using the .item attribute:
p = device.property(...)
LOGGER.info(p.item)
You can also query a device for the prefix it uses when generating items, or query a device for the item base name it would use for a property:
LOGGER.info(device.item_base)
LOGGER.info(device.property_item('property_name'))
Property Values and Types
Properties do not provide or accept raw OpenHAB typed values. Instead, mmdev translates openhab typed values to python typed values and vice-versa, transparently.
OpenHAB Types are directly translated to corresponding python types:
- DecimalType values use the int type.
- OnOffType values use the bool type.
- PercentType values use the float type and should be a normalized value.
- HSBType values use the tuple type, specifically a tuple of the form (h, s, b).
- String values use the str type.
- Group values use the set type.
- Undefined openhab values translate to None, and vice versa.
Numeric values can have a dimension added with the dimension parameter in the property constructor. An example dimension would be ‘Temperature’.
A unit can be assigned to a numeric type with the unit parameter in the property constructor. When a value is assigned, the corresponding QuanityType is sent instead.
The value of a property can be retrieved by inspecting it’s .value attribute. No caching is performed; every access will re-query openhab for the value and re-translate it.
Property Mutation
The value of a property, like an item, can receive both a command and an update. By default, any updates or commands sent to a property are ignored if they are equivalent to the already set value. This can be specified either in the property constructor, or in individual command and update calls:
# declare a Num property.
p = device.property(int, 'Num', force=True)
# Num is commanded to 1
p.command = 1
# Num is updated to 2
p.update = 2
# Num is commanded to 2
p.command = 2
# Nothing happens
p.command(2, force=False)
Property Rules
OpenHAB supports a rule engine based on item changes. Likewise, mmdev supports rules based on property value changes.
Every property exposes several decorator properties, which when used on a function or method, declares the appropriate underlying OpenHAB rules.
property.on_change()
Functions decorated with the on_change decorator will trigger any time the value of a property changes. If called without arguments, the callback will be called with no arguments. If passed the pass_context=True parameter, the callback will be called with the old value and new value passed as arguments. By default, pass_context will never pass None values to the callback function; you can override this with the null_context=True parameter.
p = device.property(int, 'Value', default=0)
@p.on_change(pass_context=True)
def log_changes(_, new):
    LOGGER.log('New Value: {}'.format(new))
property.on_command()
Functions decorated with the on_command decorator will trigger any time a property receives a command. If called without arguments, the callback will be called with no arguments. If the pass_context=True parameter is passed, the callback will be called with the commanded value passed as an argument. By default, pass_context will never pass None values to the callback function; you can override this with the null_context=True parameter.
@p.on_command(pass_context=True)
def log_command(command):
    LOGGER.log('New Command: {}'.format(command))
property.on_update()
Functions decorated with the on_update decorator will trigger any time a property receives an update. If called without arguments, the callback will be called with no arguments. If passed the pass_context=True parameter, the callback will be called with the commanded value passed as an argument. By default, pass_context will never pass None values to the callback function; you can override this with the null_context=True parameter.
@p.on_update(pass_context=True)
def log_update(update):
    LOGGER.log('New Update: {}'.format(update))
property.on_activate
Calls a callback whenever the value transitions to the value True.
@p.on_activate
def activated(update):
    LOGGER.log('Activated')
property.on_deactivate
Calls a callback whenever the value transitions to the value False.
@p.on_deactivate
    LOGGER.log('Deactivated')
The Rule Engine
mmdev has an underlying rule engine object it uses to declare its rules. The rule engine associated with a device is available on that device as the rule_engine attribute. This usually isn’t useful, but there is one decorator that is available from the rule engine that is very useful.
device.rule_engine.loop is a special decorator that registers a callback to execute once a minute. It also automatically distributes the timers across the time span of a minute, so that the rule load is a little more evenly distributed.
@device.rule_engine.loop
def log():
     LOGGER.info('Loop')
If you need a rule that is not available via the aforementioned methods, you can share any rule you like with a rule decorator bundled with mmdev. Rules decorated with this decorator will have the event object associated with the rule passed to them if they specify pass_confext=True.
from community.mmdev.rules import rule
@rule("cron '...')
def update():
    LOGGER.info('cron')
Property Channels
Each property can have a single optional channel attached to it. This channel is declared when creating the property:
power = device.property(
    int, 'PortableACPower', default=0,
    channel='tplinksmarthome:hs300:powerstrip_ac:outlet2#power'
Property Defaults
The items backing a property can be given a default value. This value is assigned to the property either the first time the item is created, or any time openhab boots while the property contains None. The default value is specified as part of the property constructor:
Property Groups
Properties support having OpenHAB groups assigned to them during property construction via the groups parameter.
The value passed to this parameter MUST BE a property object, not an item name:
g1 = device.group_for('TestGroup1')
g2 = device.group_for('TestGroup2')
device.property(
    groups={g1, g2},
Property Proxying
When a property is instantiated, a proxy property can be provided alongside it. If a proxy property is provided, then no new item is created, and all property method calls on the new property will be redirected to call the proxy property’s methods. Metadata and groups will be actively merged with the existing metadata and groups on the proxied property.
test = device.property(int, 'Test', default=False)
proxy = device.property(int, 'Proxy', proxy=test)
# The underlying item for the Proxy property is never created.
Groups
Groups are set type properties with no associated device.
Groups can be created either with either the device object’s, or device manager object’s, group_for method. Both accept a metadata parameter for the group’s metadata.
m = Manager()
g = m.group_for('Test', metadata={})
g = device.group_for('Test', metadata={})
State Properties
State properties are properties unbound from a device, and can be created with a device manager’s state_for method. It accepts all the same parameters as a device property.
m = Manager()
sleeping = m.state_for(bool, 'Sleeping', default=False)
Ephemeral Devices
Special ephemeral device objects can be created with the device manager’s ephemeral_for method. It requires a room and device name, and returns a special device object. This device object has an overridden property method on it that, in addition to creating a property, also exposes it as an attribute on the device object. The name of the attribute is determined by converting it from CamelCase to camel_case, where spaces are stripped before conversion.
m = Manager()
dev = m.ephemeral_for('Living Room', 'Test')
test = dev.property(bool, 'Test', default=False)
@dev.test.on_change()
def test_change():
    LOGGER.error(test.value)
Defining a Device Class
Device classes are very simple:
The class object can have an optional collection and name attribute defining the device class collection and device class name. If not defined, the collection and name will be inferred from the module path of the device, and the device class name, respectively.
All device classes must have an init function that accepts a single parameter device (in addition to self) and any number of keyword parameters. Keyword parameters can be provided to the device manager when creating an instance of the device.
Using the @as_device helper
Instead of creating a device class directly, it is recommended that you use the @as_device decorator from community.mmdev.device when defining device classes. This decorator optionally accepts both a specific collection and device name, which are otherwise inferred.
The decorator takes a function with a singular parameter device and any number of keyword arguments. The keyword arguments can be provided when instantiating the device with a device manager.
The function is called when the device is created. It is passed a device object that the function can define properties on, and define behaviors around. Finally, the function returns a set of properties it wants exposed publicly, or the empty set of the entire device is private.
The device object also allows the function to create groups specific to the device with the group_for method, and allows access to a rule engine if needed through it’s rule_engine attribute.
Finally, if you pass it the ephermeral=True parameter, it will generate a random collection and name to avoid clashing with any other existing device classes. This is useful when used in your startup scripts.
Here is an example defining a Lock class which locks itself if it has been unlocked for longer than a specified time (60 seconds by default):
from time import time
@as_device(collection='Example')
def Lock(device, timeout=60):
    locked = device.property(bool, 'Locked', default=False)
    last_transition = device.property(int, 'LastTransition', default=0)
    @locked.on_change()
    def transition():
        last_transition.command = time()
    def check_lock():
        if time() - last_transition.value < timeout:
            return
        if locked.value:
            return
        locked.command = True
    return {
        locked
m = Manager()
lock = m.device_for(
    device_class=Lock,
    room_name='Hallway',
    device_name='Lock',
    timeout=300
The property set returned from the function does two things:
  • It exposes the properties as attributes on the resulting device object. The attribute names are based on the property names after translation from CamelCase to camel_case while ignoring spaces.
  • It exposes a number of keyword arguments to influence the created properties.
The keyword arguments take the following form, where prop is the property name of the created property:
  • {prop}_channel
  • {prop}_groups
  • {prop}_metadata
  • {prop}_default
  • {prop}_proxy
  • {prop}_normalize
These keyword arguments will pass themselves to the underlying property’s constructor when the function creates it. This is only done for returned properties, all other properties can be seen as “private properties”.
    device_name='Lock',
    locked_channel='mqtt:topic:locked:hallway'
This is the primary reason using @as_device is recommended: The extra keyword arguments gives you an easy way to assign channels and groups to devices as needed.
Garbage Collection
Item creation and garbage collection works in the following way:
All items created by properties have a heartbeat in their metadata. A cron job updates it once a minute for each live item that mmdev knows about.
A garbage collection daemon checks once a minute, and deletes any items that have a heartbeat older than 5 minutes.
When items are created, mmdev will delay itself for a couple minutes to allow the item to appear and get initialized. Only after this wait will it create items. This means a fresh boot might take a few minutes before you see object behavior working. This is fine so that persistent items have time to restore their value before you use them.
This method of garbage collection was chosen as it allows items from multiple user scripts to co-exist easily, and with a lack of any available IPC mechanisms.
All mmdev items begin with MMDEV_, and the garbage collector will ignore any item that doesn’t follow that pattern.
Example User Script
Since all my security tokens exist in things configuration, I currently keep a copy of the script that controls my apartment here.
Thank you so much for posting, omfg
