Hallo!
In Openhab2 with the Modbus binding 1.9 I try to read some values from my SPS. I’m unable to see changes depending on the modbus in Openhab-Basic UI.
I tested with pollmb that the parameters for the modbus are right and I get changes on the modbus result.
In modbus.cfg I defined:
tcp.windows.connection=10.0.1.63:502:60:0:0:3:100
tcp.windows.type=input
tcp.windows.id=0
tcp.windows.start=50
tcp.windows.length=3
tcp.windows.valuetype=bit
In my items definition:
Contact Fenster_Arbeitszimmer “Fenster” (Fenster,Arbeitszimmer) {modbus:“windows:1”}
Any hints?
Thanks…
Update: found via Karaf:
[WARN ] [nternal.ModbusGenericBindingProvider] - bindingConfig is NULL (item=Rauchmelder_Arbeitszimmer (Type=ContactItem, State=Uninitialized)) -> processing bindingConfig aborted!
