Same connection as me then.
And you have managed to connect your HF221 to your wifi network? And have configured your HF221 as described under Post 144? I have also set up the following under “Serial Port Settings”:
For me, after having configured the HF221, installing the Modbus binding from PaperUI, my Modbus bridge was created using PaperUI and connected instantly.
