Hi
I’m trying to implement the modbus binding in OH2, I have don it before and it was working great.
For some reason I manage to write a wrong IP in the config file, I tried to change it back but the IP address was stuck. I also changed the modbus slave name from slave to slave1. Of course this name change got stuck too. I have tried to uninstall the binding several times from Paper UI and deleted it from the services folder, but no luck. Does anyone have I clue whats wrong?
Hey!
Unfortunatley, I cannot help you. But I like to thank you for your work.
Without modbus I cannot use openHAB for my purposes. Espessially the use case of rollershutter is of my interest (see this: Modbus binding of rollershutter).
I had the same problem and solved it by reinstalling OS
But later I noticed the directory/var/lib/openhab2/cache/org.eclipse.osgi/7/data/config/org/openhab and the modbus.config file inside it. You might consider taking a look at it, maybe it has your old configuration.
