I’ve stuck with issue trying to establish a basic connection to my controller over Modbus TCP binding
I am continuously getting “connection time out error”.
Some facts:
- I am able to ping and telnet controller.
- I am able to communicate with the controller using another tool(ModbusPoll -> ConnectionType:Modbus TCP/IP)
- There are no active telnets and ModbusPoll connection when openhab is trying to connect and failing
- I can’t establish a connection from ModbusPoll or telnet when openhabian is continuously pooling controller
- I play with bridge timeout values up to 3 seconds - does not help
- Controler - Owen Plc 110
Thing config(based on provided example in doc):
Bridge modbus:tcp:oven “Modbus Bridge” [ host = “192.168.31.31”, port = 502, id = 0, connectTimeoutMillis = 4000, timeBetweenReconnectMillis = 2000 ] {
// // read-write for holding registers. Reading 4 registers, with index 1500, 1501, 1502, 1503.
// // These correspond to holding register numbers 401501, 401502, 401503, 401504.
Bridge poller holding [ start=0, length=1, refresh=3000, type=“holding”] {
Thing data holding1500 [ readStart=“0”, readValueType=“int16”, writeStart=“0000”, writeValueType=“int16”, writeType=“holding” ]
I’ve also play with reading coils - the same exeption.
LOG:
2019-03-16 13:27:14.796 [DEBUG] [wimpi.modbus.net.TCPMasterConnection] - connect()
2019-03-16 13:27:18.803 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - connect try 1/1 error: connect timed out. Connection TCPMasterConnection@69cd74[socket=Socket[unconnected]]. Endpoint ModbusTCPSlaveEndpoint@87c8ca[address=192.168.31.31,port=502]
2019-03-16 13:27:18.807 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - re-connect reached max tries 1, throwing last error: connect timed out. Connection TCPMasterConnection@69cd74[socket=Socket[unconnected]]. Endpoint ModbusTCPSlaveEndpoint@87c8ca[address=192.168.31.31,port=502]
2019-03-16 13:27:18.810 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - Error connecting connection TCPMasterConnection@69cd74[socket=Socket[unconnected]] for endpoint ModbusTCPSlaveEndpoint@87c8ca[address=192.168.31.31,port=502]: connect timed out
2019-03-16 13:27:18.815 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Could not connect to endpoint ModbusTCPSlaveEndpoint@87c8ca[address=192.168.31.31,port=502] – aborting request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@821ede[slaveId=0,functionCode=READ_MULTIPLE_REGISTERS,start=0,length=1,maxTries=3] [operation ID fa0ab1ff-9060-42f4-8926-6c0b6db710fc]
2019-03-16 13:27:18.818 [ERROR] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:oven:holding:holding1500 ‘Modbus data’ had ModbusConnectionException error on read: ModbusConnectionException(Error connecting to endpoint=ModbusTCPSlaveEndpoint@87c8ca[address=192.168.31.31,port=502])
2019-03-16 13:27:21.829 [DEBUG] [wimpi.modbus.net.TCPMasterConnection] - connect()
