Modbus Errorcode 6 with Beckhoff BK9050
Hi OpenHAB Forum.
i have installed OpenHAB2 today and trayed something with my Beckhoff BK9050.
with this config i can read all the bit`s from my 3 Controller:
tcp.BK9050_H1.connection=192.168.5.6:502:60:0:0:3
tcp.BK9050_H1.type=holding
tcp.BK9050_H1.id=1
tcp.BK9050_H1.start=2056
tcp.BK9050_H1.length=4
tcp.BK9050_H1.valuetype=bit
tcp.BK9050_H2.connection=192.168.5.5:502:60:0:0:3
tcp.BK9050_H2.type=holding
tcp.BK9050_H2.id=1
tcp.BK9050_H2.start=2048
tcp.BK9050_H2.length=4
tcp.BK9050_H2.valuetype=bit
tcp.BK9050_G1.connection=192.168.5.7:502:60:0:0:3
tcp.BK9050_G1.type=holding
tcp.BK9050_G1.id=1
tcp.BK9050_G1.start=2056
tcp.BK9050_G1.length=1
tcp.BK9050_G1.valuetype=bit
My problem is i can’t write anything to the BK9050
016-12-26 00:04:01.755 [ERROR] [.binding.modbus.internal.ModbusSlave] - ModbusSlave (BK9050_H1): error when executing write request (net.wimpi.modbus.msg.WriteSingleRegisterRequest@4b429c): Error Code = 6
2016-12-26 00:04:02.434 [ERROR] [.binding.modbus.internal.ModbusSlave] - ModbusSlave (BK9050_H1): error when executing write request (net.wimpi.modbus.msg.WriteSingleRegisterRequest@1f41fd8): Error Code = 6
2016-12-26 00:04:03.000 [ERROR] [.binding.modbus.internal.ModbusSlave] - ModbusSlave (BK9050_H1): error when executing write request (net.wimpi.modbus.msg.WriteSingleRegisterRequest@c951d3): Error Code = 6
2016-12-26 00:04:03.585 [ERROR] [.binding.modbus.internal.ModbusSlave] - ModbusSlave (BK9050_H1): error when executing write request (net.wimpi.modbus.msg.WriteSingleRegisterRequest@1370972): Error Code = 6
2016-12-26 00:04:03.994 [ERROR] [.binding.modbus.internal.ModbusSlave] - ModbusSlave (BK9050_H1): error when executing write request (net.wimpi.modbus.msg.WriteSingleRegisterRequest@4b31e7): Error Code = 6
i think the items and the mapping are ok, because i trayed a third Party modbos tool and set some bits and i can read the correct state
Switch	mb_licht_OG_Office				"BĂĽro"					<light>		(rOG_Office)			{modbus="BK9050_H1:47"}
That’s right. Even though the Modbus binding provides a convenience feature to read bits from holding register tyres, there is no means to write individual bits.
Does the Beckhoff unit provide access as coil types?
Or see
Hi rossko57,
after changing the config to coil, the start Position and the length it looks greate.
thx!
tcp.BK9050_H1.type=coil
tcp.BK9050_H1.id=1
tcp.BK9050_H1.start=0
tcp.BK9050_H1.length=64
tcp.BK9050_H2.type=coil
tcp.BK9050_H2.id=1
tcp.BK9050_H2.start=0
tcp.BK9050_H2.length=64
tcp.BK9050_G1.type=coil
tcp.BK9050_G1.id=1
tcp.BK9050_G1.start=0
tcp.BK9050_G1.length=64
