Modbus errors
I have alot of this errors in my log. Would it be possible to give a Waring when it retries and Error when al retries fails?
2021-01-18 11:20:47.094 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - connect try 1/5 error: connect timed out. Connection TCPMasterConnection@e533c0[socket=Socket[unconnected]]. Endpoint ModbusTCPSlaveEndpoint@1d6b7db[address=192.168.192.68,port=502]
2021-01-18 11:21:43.347 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - connect try 1/5 error: connect timed out. Connection TCPMasterConnection@7a5fca[socket=Socket[unconnected]]. Endpoint ModbusTCPSlaveEndpoint@1d6b7db[address=192.168.192.68,port=502]
2021-01-18 11:22:50.964 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - connect try 1/5 error: connect timed out. Connection TCPMasterConnection@a4de66[socket=Socket[unconnected]]. Endpoint ModbusTCPSlaveEndpoint@1d6b7db[address=192.168.192.68,port=502]
@ssalonen Do you have any input on this?
off-topic ; you could try fixing the underlying error by use of timeBetweenReconnectMillis parameter
I can not se how this parameters should change that it is timing out on the first try?
We donā€™t know why it times out on the first try, but it might be because the remote end is still tidying up the old connection and will not yet accept a new connection. It might work better if you allow more time between a disconnect and reconnect.
I am just pulling every 60 sec.
Alright, weā€™ve seen devices before that do not disconnect cleanly with the default binding settings. Try increasing reconnectAfterMillis to an hour or so.
Good suggestion adjusting logging.
Would you like make a PR?
openhab-core/ModbusSlaveConnectionFactoryImpl.java at main Ā· openhab/openhab-core Ā· GitHub line 322
I will look into if i can do a PR :slight_smile:
If i use reconnectAfterMillis it does not reconnect and i get to much updates.
You are always using reconnectAfterMillis whether you set it to something non-default or not, it exists and is used.
If you want some help with that, please say what you are doing and what ā€˜too much updatesā€™ means.
PR done.
Can you check it i missed something.
