I have tried the Modbus Rollershutter example from the Binding documentation.
I have adapted the Things file according to my configuration.
Every time I execute a command the write transformation writes to the wrong Modbus address. Is it the Write Transformation or the Thing configuration?
things
Bridge modbus:tcp:localhostTCPRollerShutter [ host="192.168.178.25", port=502 ] {
Bridge poller holding [ start=32006, length=3, refresh=1000, type="holding" ] {
// Since we are using advanced transformation outputting JSON,
// other write parameters (writeValueType, writeStart, writeType) can be omitted
Thing data rollershutterData [ readStart="32006", readValueType="int16",writeStart="32006", writeTransform="JS:rollershutter.js", writeValueType="int16", writeType="holding" ]
// For diagnostics
Thing data rollershutterDebug0 [ readStart="32006", readValueType="int16", writeStart="32006", writeValueType="int16", writeType="holding" ]
Thing data rollershutterDebug1 [ readStart="32007", readValueType="int16" ]
Thing data rollershutterDebug2 [ readStart="32008", readValueType="int16" ]
items
// We disable auto-update to make sure that rollershutter position is updated from the slave, not "automatically" via commands
Rollershutter RollershutterItem "Roller shutter position [%.1f]" <temperature> { autoupdate="false", channel="modbus:data:localhostTCPRollerShutter:holding:rollershutterData:rollershutter" }
// For diagnostics
Number RollershutterItemDebug0 "Roller shutter Debug 0 [%d]" <temperature> { channel="modbus:data:localhostTCPRollerShutter:holding:rollershutterDebug0:number" }
Number RollershutterItemDebug1 "Roller shutter Debug 1 [%d]" <temperature> { channel="modbus:data:localhostTCPRollerShutter:holding:rollershutterDebug1:number" }
Number RollershutterItemDebug2 "Roller shutter Debug 2 [%d]" <temperature> { channel="modbus:data:localhostTCPRollerShutter:holding:rollershutterDebug2:number" }
sitemap
sitemap modbus_ex_rollershutter label="modbus_ex_rollershutter" {
Switch item=RollershutterItem label="Roller shutter [(%d)]" mappings=[UP="up", STOP="X", DOWN="down", MOVE="move"]
// For diagnostics
Setpoint item=RollershutterItemDebug0 minValue=0 maxValue=100 step=20
Text item=RollershutterItemDebug0
Text item=RollershutterItemDebug1
Text item=RollershutterItemDebug2
// Wrap everything in a function
// variable "input" contains data passed by openHAB
(function(cmd) {
var cmdToValue = {"UP": 1, "DOWN": -1, "MOVE": 1, "STOP": 0};
var cmdToAddress = {"UP": 1, "DOWN": 1, "MOVE": 2, "STOP": 2};
var value = cmdToValue[cmd];
var address = cmdToAddress[cmd];
if(value === undefined || address === undefined) {
// unknown command, do not write anything
return "[]";
} else {
return (
+ "{\"functionCode\": 6, \"address\":" + address.toString() + ", \"value\": [" + value + "] }"
})(input)
log
2021-05-11 12:50:57.110 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 1 out of 3 failed when executing request (ModbusWriteRegisterRequestBlueprint [slaveId=1, reference=1, registers=ModbusRegisterArray(0001), maxTries=3, getFunctionCode()=WRITE_SINGLE_REGISTER]). Will try again soon. Error was: net.wimpi.modbus.ModbusSlaveException Error Code = 2 [operation ID 27663d15-548b-4977-8829-89d15a02b067]
2021-05-11 12:50:57.173 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 2 out of 3 failed when executing request (ModbusWriteRegisterRequestBlueprint [slaveId=1, reference=1, registers=ModbusRegisterArray(0001), maxTries=3, getFunctionCode()=WRITE_SINGLE_REGISTER]). Will try again soon. Error was: net.wimpi.modbus.ModbusSlaveException Error Code = 2 [operation ID 27663d15-548b-4977-8829-89d15a02b067]
2021-05-11 12:50:57.238 [ERROR] [rt.modbus.internal.ModbusManagerImpl] - Last try 3 failed when executing request (ModbusWriteRegisterRequestBlueprint [slaveId=1, reference=1, registers=ModbusRegisterArray(0001), maxTries=3, getFunctionCode()=WRITE_SINGLE_REGISTER]). Aborting. Error was: net.wimpi.modbus.ModbusSlaveException Error Code = 2 [operation ID 27663d15-548b-4977-8829-89d15a02b067]
In the log you can see that it wants to write to register 0001. But in the Thing config I have set register 30006.
Setup:
Openhab 3.1m3 on Windows
Thanks for Answers
