Dear Sami
Coming back to my post 8 days ago: Most of the things I could get running (was an issue on USR IOT side). I have only one problem left. Reading registers is not a problem, but when trying to write into a register, that does not work. E.g. When trying to do it via paper UI:
I type in a different value, e.g. 210 however number goes always back to 230 (even when typing (maybe it has something to do wish refreshing?)
the things file looks like that:
Bridge modbus:tcp:Pool [ host="192.168.178.30", port=502, id=1 ] {
Bridge poller holding_high [ start=128, length=45, refresh=500, type="holding"]{
Thing data holding134 [ readStart="134", readValueType="uint16", writeStart="134", writeValueType="uint16", writeType="holding" ]
The item file like that:
Number Pumpenspannung "Sollspannung [%.0f V]" {channel="modbus:data:Pool:holding_high:holding134:number"}
When trying to adjust the number via sitemap also this does not work:
Setpoint item=Sollspannung minValue=0 maxValue=230 step=10 icon=temperature
It would be great to get a hint on this issue
Thank you in advance and best regards
Rolf
