Hi, I’m back
The situation is:
- I have set up new instance of openhab (stable 2.3) and put latest snapshot of the binding
- I have set up logging to TRACE
- I have currently set 102 things (colis). Note: This is only part of the system
Current configuration (full config contains 799 markers(coils) as stated below):
Bridge modbus:serial:fatekplcusb0 "FatekPLC_USB0" [ baud=115200, timeBetweenTransactionsMillis=60, cacheMillis=500, connectMaxTries=1, stopBits="1.0", parity="none", receiveTimeoutMillis=1500, dataBits=8, echo=false, encoding="rtu", flowControlIn="none", port="/dev/ttyUSB0", flowControlOut="none", connectTimeoutMillis=10000, id=1 ] {
Bridge poller coils_Y0_to_Y255 "FatekPLC_Poller_Y0_to_Y255" [ start=0, length=256, refresh=1000, type="coil" ] {
// Note the zero based indexing: first coil is index 0.
Thing data FatekPLC_Modbus_Y0 "FatekPLC_Modbus_Y0" @ "Modbus" [ readStart="0", readValueType="bit", writeStart="0", writeValueType="bit", writeType="coil" ]
Thing data FatekPLC_Modbus_Y1 "FatekPLC_Modbus_Y1" @ "Modbus" [ readStart="1", readValueType="bit", writeStart="1", writeValueType="bit", writeType="coil" ]
//M0 to M799
Bridge poller markers_M0_to_M799 "FatekPLC_Poller_M0_to_M199" [ start=2000, length=800, refresh=2000, type="coil" ] {
Thing data FatekPLC_Modbus_M0 "FatekPLC_Modbus_M0000" @ "Modbus" [ readStart="2000", readValueType="bit", writeStart="2000", writeValueType="bit", writeType="coil" ]
Thing data FatekPLC_Modbus_M1 "FatekPLC_Modbus_M0001" @ "Modbus" [ readStart="2001", readValueType="bit", writeStart="2001", writeValueType="bit", writeType="coil" ]
//Thing data FatekPLC_Modbus_M2 "FatekPLC_Modbus_M0002" @ "Modbus" [ readStart="2002", readValueType="bit", writeStart="2002", writeValueType="bit", writeType="coil" ]
//Thing data FatekPLC_Modbus_M3 "FatekPLC_Modbus_M0003" @ "Modbus" [ readStart="2003", readValueType="bit", writeStart="2003", writeValueType="bit", writeType="coil" ]
//Thing data FatekPLC_Modbus_M4 "FatekPLC_Modbus_M0004" @ "Modbus" [ readStart="2004", readValueType="bit", writeStart="2004", writeValueType="bit", writeType="coil" ]
//Thing data FatekPLC_Modbus_M5 "FatekPLC_Modbus_M0005" @ "Modbus" [ readStart="2005", readValueType="bit", writeStart="2005", writeValueType="bit", writeType="coil" ]
//Thing data FatekPLC_Modbus_M6 "FatekPLC_Modbus_M0006" @ "Modbus" [ readStart="2006", readValueType="bit", writeStart="2006", writeValueType="bit", writeType="coil" ]
//Thing data FatekPLC_Modbus_M7 "FatekPLC_Modbus_M0007" @ "Modbus" [ readStart="2007", readValueType="bit", writeStart="2007", writeValueType="bit", writeType="coil" ]
Thing data FatekPLC_Modbus_M8 "FatekPLC_Modbus_M0008" @ "Modbus" [ readStart="2008", readValueType="bit", writeStart="2008", writeValueType="bit", writeType="coil" ]
Thing data FatekPLC_Modbus_M9 "FatekPLC_Modbus_M0009" @ "Modbus" [ readStart="2009", readValueType="bit", writeStart="2009", writeValueType="bit", writeType="coil" ]
//Thing data FatekPLC_Modbus_M10 "FatekPLC_Modbus_M0010" @ "Modbus" [ readStart="2010", readValueType="bit", writeStart="2010", writeValueType="bit", writeType="coil" ]
Thing data FatekPLC_Modbus_M11 "FatekPLC_Modbus_M0011" @ "Modbus" [ readStart="2011", readValueType="bit", writeStart="2011", writeValueType="bit", writeType="coil" ]
Thing data FatekPLC_Modbus_M12 "FatekPLC_Modbus_M0012" @ "Modbus" [ readStart="2012", readValueType="bit", writeStart="2012", writeValueType="bit", writeType="coil" ]
Thing data FatekPLC_Modbus_M13 "FatekPLC_Modbus_M0013" @ "Modbus" [ readStart="2013", readValueType="bit", writeStart="2013", writeValueType="bit", writeType="coil" ]
//Thing data FatekPLC_Modbus_M14 "FatekPLC_Modbus_M0014" @ "Modbus" [ readStart="2014", readValueType="bit", writeStart="2014", writeValueType="bit", writeType="coil" ]
//Thing data FatekPLC_Modbus_M15 "FatekPLC_Modbus_M0015" @ "Modbus" [ readStart="2015", readValueType="bit", writeStart="2015", writeValueType="bit", writeType="coil" ]
Thing data FatekPLC_Modbus_M16 "FatekPLC_Modbus_M0016" @ "Modbus" [ readStart="2016", readValueType="bit", writeStart="2016", writeValueType="bit", writeType="coil" ]
Thing data FatekPLC_Modbus_M17 "FatekPLC_Modbus_M0017" @ "Modbus" [ readStart="2017", readValueType="bit", writeStart="2017", writeValueType="bit", writeType="coil" ]
//Thing data FatekPLC_Modbus_M18 "FatekPLC_Modbus_M0018" @ "Modbus" [ readStart="2018", readValueType="bit", writeStart="2018", writeValueType="bit", writeType="coil" ]
Thing data FatekPLC_Modbus_M19 "FatekPLC_Modbus_M0019" @ "Modbus" [ readStart="2019", readValueType="bit", writeStart="2019", writeValueType="bit", writeType="coil" ]
Thing data FatekPLC_Modbus_M20 "FatekPLC_Modbus_M0020" @ "Modbus" [ readStart="2020", readValueType="bit", writeStart="2020", writeValueType="bit", writeType="coil" ]
//Thing data FatekPLC_Modbus_M21 "FatekPLC_Modbus_M0021" @ "Modbus" [ readStart="2021", readValueType="bit", writeStart="2021", writeValueType="bit", writeType="coil" ]
//Thing data FatekPLC_Modbus_M22 "FatekPLC_Modbus_M0022" @ "Modbus" [ readStart="2022", readValueType="bit", writeStart="2022", writeValueType="bit", writeType="coil" ]
//Thing data FatekPLC_Modbus_M23 "FatekPLC_Modbus_M0023" @ "Modbus" [ readStart="2023", readValueType="bit", writeStart="2023", writeValueType="bit", writeType="coil" ]
//Thing data FatekPLC_Modbus_M24 "FatekPLC_Modbus_M0024" @ "Modbus" [ readStart="2024", readValueType="bit", writeStart="2024", writeValueType="bit", writeType="coil" ]
Thing data FatekPLC_Modbus_M25 "FatekPLC_Modbus_M0025" @ "Modbus" [ readStart="2025", readValueType="bit", writeStart="2025", writeValueType="bit", writeType="coil" ]
Thing data FatekPLC_Modbus_M26 "FatekPLC_Modbus_M0026" @ "Modbus" [ readStart="2026", readValueType="bit", writeStart="2026", writeValueType="bit", writeType="coil" ]
Thing data FatekPLC_Modbus_M27 "FatekPLC_Modbus_M0027" @ "Modbus" [ readStart="2027", readValueType="bit", writeStart="2027", writeValueType="bit", writeType="coil" ]
Thing data FatekPLC_Modbus_M28 "FatekPLC_Modbus_M0028" @ "Modbus" [ readStart="2028", readValueType="bit", writeStart="2028", writeValueType="bit", writeType="coil" ]
Thing data FatekPLC_Modbus_M29 "FatekPLC_Modbus_M0029" @ "Modbus" [ readStart="2029", readValueType="bit", writeStart="2029", writeValueType="bit", writeType="coil" ]
//Thing data FatekPLC_Modbus_M30 "FatekPLC_Modbus_M0030" @ "Modbus" [ readStart="2030", readValueType="bit", writeStart="2030", writeValueType="bit", writeType="coil" ]
This is my current Fatek config:
With this configuration it works without issues thaat I have had before, however I’m not satisfied since i observe the following behavior when I turn on/off switch:
2018-07-03 23:05:05.815 [ome.event.ItemCommandEvent] - Item 'Kitchen_Bar_Table_Light' received command ON
2018-07-03 23:05:05.865 [vent.ItemStateChangedEvent] - Kitchen_Bar_Table_Light changed from OFF to ON
2018-07-03 23:05:07.430 [vent.ItemStateChangedEvent] - Kitchen_Bar_Table_Light changed from ON to OFF
2018-07-03 23:05:09.590 [vent.ItemStateChangedEvent] - Kitchen_Bar_Table_Light changed from OFF to ON
2018-07-03 23:05:09.604 [vent.ItemStateChangedEvent] - Kitchen_Bar_Table_Light_GH changed from OFF to ON
2018-07-03 23:05:19.819 [ome.event.ItemCommandEvent] - Item 'Kitchen_Bar_Table_Light' received command OFF
2018-07-03 23:05:19.850 [vent.ItemStateChangedEvent] - Kitchen_Bar_Table_Light changed from ON to OFF
2018-07-03 23:05:21.715 [vent.ItemStateChangedEvent] - Kitchen_Bar_Table_Light changed from OFF to ON
2018-07-03 23:05:23.718 [vent.ItemStateChangedEvent] - Kitchen_Bar_Table_Light changed from ON to OFF
2018-07-03 23:05:23.729 [vent.ItemStateChangedEvent] - Kitchen_Bar_Table_Light_GH changed from ON to OFF
2018-07-03 23:05:51.028 [ome.event.ItemCommandEvent] - Item 'Kitchen_Bar_Table_Light' received command ON
2018-07-03 23:05:51.043 [vent.ItemStateChangedEvent] - Kitchen_Bar_Table_Light changed from OFF to ON
2018-07-03 23:05:51.731 [vent.ItemStateChangedEvent] - Kitchen_Bar_Table_Light changed from ON to OFF
2018-07-03 23:05:53.808 [vent.ItemStateChangedEvent] - Kitchen_Bar_Table_Light changed from OFF to ON
2018-07-03 23:05:53.813 [vent.ItemStateChangedEvent] - Kitchen_Bar_Table_Light_GH changed from OFF to ON
2018-07-03 23:06:00.017 [ome.event.ItemCommandEvent] - Item 'Kitchen_Bar_Table_Light' received command OFF
2018-07-03 23:06:00.042 [vent.ItemStateChangedEvent] - Kitchen_Bar_Table_Light changed from ON to OFF
2018-07-03 23:06:00.272 [vent.ItemStateChangedEvent] - Kitchen_Bar_Table_Light changed from OFF to ON
2018-07-03 23:06:04.150 [vent.ItemStateChangedEvent] - Kitchen_Bar_Table_Light changed from ON to OFF
2018-07-03 23:06:04.163 [vent.ItemStateChangedEvent] - Kitchen_Bar_Table_Light_GH changed from ON to OFF
So when I switch light on, it turns on correctly however the status bar in habdroid turns on, then off then on again. The above log shows it as I described. Same behavior I see in Basic UI.
A least it sets the correct state in the end, however only if I wait for the full cycle. If I do it too quickly the state sets often to wrong value.
