- openHAB version: 4.1
Hi:
I am running into a problem when reading from a sensor using Modbus
The Modbus serial slave shows ONLINE
Here is the code
UID: modbus:serial:88e20f2440
label: Modbus Serial Slave
thingTypeUID: modbus:serial
configuration:
baud: 9600
connectMaxTries: 1
timeBetweenTransactionsMillis: 35
stopBits: "1.0"
parity: none
receiveTimeoutMillis: 1500
dataBits: 8
echo: false
encoding: rtu
flowControlIn: none
flowControlOut: none
port: COM8
connectTimeoutMillis: 10000
afterConnectionDelayMillis: 0
enableDiscovery: false
The Regular Poll
Code
UID: modbus:poller:d27deb0c81:a755cb7923
label: Regular Poll
thingTypeUID: modbus:poller
configuration:
length: 1
start: 0
refresh: 5000
maxTries: 3
cacheMillis: 50
type: holding
bridgeUID: modbus:serial:88e20f2440
gives this error
Status:
OFFLINE
COMMUNICATION_ERROR
Error with read: org.openhab.core.io.transport.modbus.internal.ModbusSlaveIOExceptionImpl: Modbus IO Error with cause=ModbusIOException, EOF=false, message='I/O exception: IOException Error reading response (EOF)', cause2=null
However if I use QModMaster to communicate with the sensor it works without any issues
Does anyone more versed than me have any idea what it is I am missing?
Thank you
