Took some time to look into the modbus item caching but it still makes my mind go in circles. Hope you guys can help.
I have a SMA Tripower solar inverter which I connect to in OpenHAB via Modbus TCP, all is fine after a reboot. all items do their thing in the right way. But after I edit the things file to change the poll interval for instance a couple of items stop working. Some poll items stop completely other items inside one poll item stop updating.
Also if I connect to a LAN IOT RS485 to a modbus slave I have the same issue. Items going offline. It is working fine at first, after a change in the item file the poller or the items goes offline.
After some searching I discovered items cache which could be an issue. Not sure how it works and why this only happens on my modbus items
I have a snapshot of today where I changed the refresh time from 15000 to 10000. There is a flat line on some items after the change of the file.
https://snapshot.raintank.io/dashboard/snapshot/XgxsuJKIEIGzqjnKtS8lCnlgAdICDOyI?orgId=2
SMA things file
Bridge modbus:tcp:endpointSMA [ host="192.168.1.200", port=502, id=3 ] {
Bridge poller SMA_Yield [ start=30531, length=2, refresh=10000, type="input" ] {
Thing data SMA_Yield [ readStart="30531", readValueType="uint32"]
Bridge poller SMA_DC1 [ start=30769, length=6, refresh=10000, type="input" ] {
Thing data SMA_DC_A_1 [ readStart="30769", readValueType="int32", readTransform="JS(divide1000.js)"]
Thing data SMA_DC_V_1 [ readStart="30771", readValueType="int32", readTransform="JS(divide100.js)"]
Thing data SMA_DC_P_1 [ readStart="30773", readValueType="int32", readTransform="JS(normalize.js)"]
Bridge poller SMA_DC2 [ start=30957, length=6, refresh=10000, type="input" ] {
Thing data SMA_DC_A_2 [ readStart="30957", readValueType="int32", readTransform="JS(divide1000.js)"]
Thing data SMA_DC_V_2 [ readStart="30959", readValueType="int32", readTransform="JS(divide100.js)"]
Thing data SMA_DC_P_2 [ readStart="30961", readValueType="int32", readTransform="JS(normalize.js)"]
Bridge poller SMA_ACV [ start=30783, length=6, refresh=10000, type="input" ] {
Thing data SMA_AC_V_L1 [ readStart="30783", readValueType="uint32", readTransform="JS(divide100.js)"]
Thing data SMA_AC_V_L2 [ readStart="30785", readValueType="uint32", readTransform="JS(divide100.js)"]
Thing data SMA_AC_V_L3 [ readStart="30787", readValueType="uint32", readTransform="JS(divide100.js)"]
Bridge poller SMA_ACAMPERE [ start=30977, length=6, refresh=10000, type="input" ] {
Thing data SMA_AC_A_L1 [ readStart="30977", readValueType="int32", readTransform="JS(divide1000.js)"]
Thing data SMA_AC_A_L2 [ readStart="30979", readValueType="int32", readTransform="JS(divide1000.js)"]
Thing data SMA_AC_A_L3 [ readStart="30981", readValueType="int32", readTransform="JS(divide1000.js)"]
Bridge poller SMA_Power [ start=30775, length=2, refresh=10000, type="input" ] {
Thing data SMA_Power [ readStart="30775", readValueType="int32", readTransform="JS(normalize.js)"]
Bridge poller SMA_Temperature [ start=30953, length=2, refresh=10000, type="input" ] {
Thing data SMA_Temperature [ readStart="30953", readValueType="int32", readTransform="JS(divide10.js)"]
Errors in the log file
2019-04-10 13:57:51.806 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'SMA_ModBus.things'
2019-04-10 13:57:52.244 [INFO ] [rt.modbus.internal.ModbusManagerImpl] - Unregistering regular poll task BasicPollTaskImpl@1f5cd31[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@1a96b4f[slaveId=3,functionCode=READ_INPUT_REGISTERS,start=30783,length=6,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@1a0e45a[address=192.168.1.200,port=502],callback=org.openhab.binding.modbus.internal.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@1f7ccc78] (interrupting if necessary)
2019-04-10 13:57:52.248 [INFO ] [rt.modbus.internal.ModbusManagerImpl] - Poll task BasicPollTaskImpl@1f5cd31[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@1a96b4f[slaveId=3,functionCode=READ_INPUT_REGISTERS,start=30783,length=6,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@1a0e45a[address=192.168.1.200,port=502],callback=org.openhab.binding.modbus.internal.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@1f7ccc78] canceled
2019-04-10 13:57:52.257 [hingStatusInfoChangedEvent] - 'modbus:poller:endpointSMA:SMA_ACV' changed from ONLINE to OFFLINE
2019-04-10 13:57:52.265 [hingStatusInfoChangedEvent] - 'modbus:data:endpointSMA:SMA_ACV:SMA_AC_V_L1' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-04-10 13:57:52.273 [hingStatusInfoChangedEvent] - 'modbus:data:endpointSMA:SMA_ACV:SMA_AC_V_L3' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-04-10 13:57:52.278 [me.event.ThingUpdatedEvent] - Thing 'modbus:poller:endpointSMA:SMA_ACV' has been updated.
2019-04-10 13:57:52.281 [INFO ] [rt.modbus.internal.ModbusManagerImpl] - Unregistering regular poll task BasicPollTaskImpl@1fbbdb2[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@13c44fd[slaveId=3,functionCode=READ_INPUT_REGISTERS,start=30977,length=6,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@1a0e45a[address=192.168.1.200,port=502],callback=org.openhab.binding.modbus.internal.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@70dafaea] (interrupting if necessary)
2019-04-10 13:57:52.282 [hingStatusInfoChangedEvent] - 'modbus:data:endpointSMA:SMA_ACV:SMA_AC_V_L2' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-04-10 13:57:52.286 [INFO ] [rt.modbus.internal.ModbusManagerImpl] - Poll task BasicPollTaskImpl@1fbbdb2[request=ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@13c44fd[slaveId=3,functionCode=READ_INPUT_REGISTERS,start=30977,length=6,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@1a0e45a[address=192.168.1.200,port=502],callback=org.openhab.binding.modbus.internal.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator@70dafaea] canceled
2019-04-10 13:57:52.294 [hingStatusInfoChangedEvent] - 'modbus:poller:endpointSMA:SMA_ACAMPERE' changed from ONLINE to OFFLINE
2019-04-10 13:57:52.300 [hingStatusInfoChangedEvent] - 'modbus:data:endpointSMA:SMA_ACAMPERE:SMA_AC_A_L1' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-04-10 13:57:52.304 [hingStatusInfoChangedEvent] - 'modbus:data:endpointSMA:SMA_ACAMPERE:SMA_AC_A_L2' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-04-10 13:57:52.307 [hingStatusInfoChangedEvent] - 'modbus:data:endpointSMA:SMA_ACAMPERE:SMA_AC_A_L3' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-04-10 13:57:52.310 [me.event.ThingUpdatedEvent] - Thing 'modbus:poller:endpointSMA:SMA_ACAMPERE' has been updated.
