Hi all,
Sorry about this question, but I’m very new to this topic. We currently installed a heat pump at home and I asked our electrician to install an energy meter to meter the power usage of that pump. Having that I would like to get an energy meter which can deliver data to my openhab server.
The electrician told me that he knows the ENERGYSENS-EScom module and he would like to use this for my setup. The datasheet told me, that the modbus (tcp/rtu) protocol is supported. But I’ve never done anything with that.
Openhab supports a modbus binding. Does anybody knows, if this works with the ENERGYSENS-EScom module? Or is modbus not as standard as each modul can be used with that binding? I can see in the binding docu, that it supports several “extensions” but don’t know what that means at the end.
Thanks in advance,
Denis
