Running fresh OpenHAB installation (3.0.1) on Synology NAS from docker-image (Docker Hub). Worked perfectly fine for several days. I then added a new location in the model and changed the parent group after saving. Now, my model disappeared. However, the start-page still shows the models’ cards correctly. What can I do to “reset” the semantic model to show up again?
The json file (userdata/jsondb/org.openhab.core.items.Item.json) is filled with all details. Adding a new location added a json entry in this file, removing it removed it. So, this seems to work fine.
Thanks in advance.
plitvicer
