HSorgYves
(Dr. Yves Kreis)
September 23, 2019, 5:49am
#1
I want to modify the switch widget. I checked the source code and the modifications should be easy. However I have no clue how to get a “copy” of the switch widget as no json file exists and it cannot be exported. Where to start?
sihui
(SiHui)
September 23, 2019, 9:11am
#2
HSorgYves:
Where to start?
A template can be adapted to whatever you want:
This Wiki post aims to be a centralized resource to help new users (and experienced users alike!) with the advanced features in HABPanel. It will contain relevant examples and links to help you with common issues and getting the most out of these features!
Users with the “Member” badge (and levels above) can edit this post, don’t hesitate to do so if you deem it appropriate
Templates & Custom Widgets
What are templates?
If the standard widgets don’t fit your needs or your taste, HAB…
HSorgYves
(Dr. Yves Kreis)
September 23, 2019, 9:28am
#3
Except that the “integrated” widgets are quite different from custom widgets… I read this and it is only of partial help!
