I made a workaround therefore.
My script allows you to create a sitemap-item.
Sitemap name="example"
It will search for a file called “example.sitemap” an inserts all it’s contents instead of the tag.
finally it will create a file named by the name in the sitemap definition of the root-file.
The root element is a file called “main.sitemap” in the folder sitemapparts.
Exmple:
sitemapparts/main.sitemap
sitemap defaultAutoGenerated label="Home"
Frame label="Wohnraum" icon="firstfloor" {
Sitemap name="livingroom.sitemap"
sitemapparts/livingroom.sitemap
Text item=gTadoBatteryLow visibility=[gTadoBatteryLow==ON]
Sitemap name="wohnraum/temp"
Sitemap name="wohnraum/lstg"
sitemapparts/wohnraum/lstg.sitemap
Group item=gHeizungLstg{
Text item=HEAT_Wohnzimmer_heating_power label="Wohnzimmer"
Text item=HEAT_Esszimmer_heating_power label="Esszimmer"
Text item=HEAT_Kueche_heating_power label="Küche"
Text item=HEAT_Badezimmer_heating_power label="Badezimmer"
Text item=HEAT_Toilette_heating_power label="Toilette"
Text item=HEAT_Arbeitszimmer_heating_power label="Arbeitszimmer"
Text item=HEAT_Schlafzimmer_heating_power label="Schlafzimmer"
Generated output
sitemaps/defaultAutoGenerated.sitemap.
// Autogenerated sitemap by Sitemapscript located in /etc/openhab2/scripts/watchdir.py
//File wohnraum/temp.sitemap doesn't exists. Therefore ignoring it.
You can use subfolders. The script will also add whitespaces in front of each row, so that the imported sitemaps will fit to the format.
The export file will be stored as sitemaps/defaultAutoGenerated.sitemap.
There will be now warning before overwriting so take care of your files.
How to:
- Create a dir /etc/openhab2/sitemapparts
sudo mkdir /etc/openhab2/sitemapparts
- Install depencies systemd and watchdog
sudo pip3 install systemd
sudo pip3 install watchdog
- Create the python script below as /etc/openhab2/scripts/watchdir.py
#!/usr/bin/env python
import watchdog.events
import watchdog.observers
import time
import re
import os.path
import logging
from systemd.journal import JournaldLogHandler
#Path to store sitemaps
global outputPath
outputPath = r"/etc/openhab2/sitemaps/"
#Debounce to avoid multiple runs
global lastBuild
lastBuild=0
# get an instance of the logger object this module will use
logger = logging.getLogger(__name__)
# instantiate the JournaldLogHandler to hook into systemd
journald_handler = JournaldLogHandler()
# set a formatter to include the level name
journald_handler.setFormatter(logging.Formatter(
'[%(levelname)s] %(message)s'
# add the journald handler to the current logger
logger.addHandler(journald_handler)
# optionally set the logging level
logger.setLevel(logging.INFO)
class Handler(watchdog.events.PatternMatchingEventHandler):
def __init__(self):
# Set the patterns for PatternMatchingEventHandler
watchdog.events.PatternMatchingEventHandler.__init__(self, patterns=['*.sitemap'],
ignore_directories=True, case_sensitive=False)
#if any event in current item hapens
def on_any_event(self, event):
global lastBuild
#and the last item was created minimum a second ago
if int(time.time())-lastBuild>1:
logger.debug(event)
print (event)
#build the sitemap
buildSitemapFile()
#Builds the Sitemaps file
def buildSitemapFile():
if not os.path.isfile('main.sitemap'):
print('Root file "main.sitemap" does not exist.')
else:
content = getFileContent('main')
#Don't continue if file is empty
if content is None:
return
#Set current time to avoud debounce
global lastBuild
lastBuild = int(time.time())
#Search for the name of the sitemap to set the filename
filename = 'noname.sitemap'
regex = r"sitemap\s*(\w*)"
matches = re.finditer(regex, content)
for matchNum, match in enumerate(matches, start=1):
filename = match.group(1)+'.sitemap'
content = "// Autogenerated sitemap by Sitemapscript located in " + os.path.realpath(__file__) + "\n\r" + content
#write sitemap to path
f = open(outputPath+filename, "w")
f.write(content)
f.close()
logger.info('wrote sitemap to '+outputPath+filename)
print ('wrote sitemap to '+outputPath+filename)
# This function reads the content of a sitemapfile.
# filename: the name of the sitemap without the .sitemap
# prespaces: a string to be set before every row to get a nice formatted file
def getFileContent(filename, prespaces=''):
filename += '.sitemap'
logger.debug('Processing file: '+filename)
print('Processing file: '+filename)
#If the file doesnt exists leave a comment in the target sitemap
if not os.path.isfile(filename):
return '//File '+ filename + ' doesn\'t exists. Therefore ignoring it.'
else:
data = ""
#Read the target file line by line and extend it by the pre-spaces
with open(filename, 'r') as fp:
line = fp.readline()
while line:
data += prespaces + line
#If the file was empty retun None
if data == "":
return None
#otherwise search for sitemap items
regex = r"^([\t ]*)Sitemap\s*name=\"([\\\/\w]*)\""
matches = re.finditer(regex, data, re.MULTILINE)
#if a sitemap item was found call getFileContent wit the sitemapname and 4 extra spaces
content = getFileContent(match.group(2),prespaces+' ')
#replace the Sitemap item with the filecontent
data = data.replace(match.group(),content)
return data
if __name__ == "__main__":
src_path = r"."
event_handler = Handler()
observer = watchdog.observers.Observer()
observer.schedule(event_handler, path=src_path, recursive=True)
observer.start()
try:
while True:
time.sleep(1)
except KeyboardInterrupt:
observer.stop()
observer.join()
- Create a service for the script
sudo nano /lib/systemd/system/sitemapWatchdog.service
The content of the file is
[Unit]
Description=Watchdog and sitemap-generator for /etc/openhab2/sitemapparts
After=multi-user.target
[Service]
Type=simple
ExecStart=/usr/bin/python3 /etc/openhab2/scripts/watchdir.py
WorkingDirectory=/etc/openhab2/sitemapparts
Restart=on-abort
StandardOutput=inherit
StandardError=inherit
User=openhab
[Install]
WantedBy=multi-user.target
- Activate the service
sudo chmod 644 /lib/systemd/system/sitemapWatchdog.service
chmod +x /etc/openhab2/scripts/watchdir.py
sudo systemctl daemon-reload
sudo systemctl enable sitemapWatchdog.service
sudo systemctl start sitemapWatchdog.service
- Create your sitemapfiles.
