Hi folks,
I’m running a Openhab 2.4.0 release build from Docker Hub using the official image. This image is missing the mongodb persistence add-on. It’s not even listed for installation in an UI nor in karaf console. What can I do install it? The reason why I’m thinking about this is: I do have a separate MongoDB Container running for another software in my home, so i want to use mongodb for persistance instead of mapdb. Can you help me?
Kind regards
Kai
- Platform information:
- Hardware: Raspberry Pi 3 with 16 GB SD-Card
- OS: Raspbian Stretch
- Java Runtime Environment: OpenJDK Runtime Environment (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 1.8.0_152-b76)
- openHAB version: 2.4.0 from hub.docker.com, Image is openhab/openhab
