I replied to another thread with the post below, which was discussing how to create rules to monitor when a sensor stops reporting.
It got a bit of interest so I was asked to start another thread. Below is a series of config I use for monitoring various parts of my openHAB system using icinga2
, MQTT
and mqttwarn
I haven’t put this in the tutorials section of the WIKI since it is by no means complete, there are loads of pieces missing in order to set this up from scratch so I don’t think it has much value unless it is fleshed out a lot, and unfortunately I don’t have the time to do this currently.
Anyway, have a read and post your thoughts/comments. Interested to hear if anyone else is doing this sort of thing and how.
Original post…
I have done most of my openHAB integration with icinga2 by adding MQTT bindings to the sensor/battery/state items I want to monitor and then implementing rules and checks via mqttwarn.
E.g. in my mqttwarn.ini
I have an icinga2
target configured;
[config:icinga2]
host = 'https://icinga2-host'
port = 5665
username = 'icinga2-api-username'
password = 'icinga2-api-password'
targets = {
# host service
'check-service' : [ 'host', 'service', 'mqttwarn' ],
Then I have a series of subscriptions (also in mqttwarn.ini
# various MQTT services/clients
[/clients/+]
targets = icinga2:check-service
format = icinga2_lwt_publish()
# zwave node alive/dead
[/network/+/+/zwave]
format = icinga2_network_zwave()
# battery reports for various sensors
[/sensor/+/+/battery]
format = icinga2_sensor_battery()
Then I have a series of functions which are being referenced in the targets above, e.g. icinga2_sensor_temp()
def icinga2_lwt_publish(data, srv):
# /clients/+
# /homie/+/$online
payload = data['payload']
parts = data['topic'].split('/')
host = parts[2]
if payload == '1' or payload == 'true':
status = 0
output = "OK: {0} is online".format(host)
else:
status = 2
output = "CRITICAL: {0} is offline".format(host)
icinga2_payload = {
'exit_status' : status,
'plugin_output' : output,
'service' : "{0}.home!mqtt-lwt".format(host),
return json.dumps(icinga2_payload)
def icinga2_network_zwave(data, srv):
if payload == 'alive':
status = 0
code = 'OK'
elif payload == 'dead':
status = 2
code = 'CRITICAL'
else:
status = 3
code = 'UNKNOWN'
# /network/location/type/zwave
location = parts[2]
type = parts[3]
host = "{0}-{1}".format(location, type)
icinga2_payload = {
'plugin_output' : "{0}: zwave node is {1}".format(code, payload),
'service' : "{0}!zwave".format(host),
def icinga2_sensor_battery(data, srv):
batt_warn = 20
batt_crit = 10
battery = int(float(data['payload']))
status = 0
code = 'OK'
if battery <= batt_warn:
status = 1
code = 'WARNING'
if battery <= batt_crit:
status = 2
code = 'CRITICAL'
# /sensor/location/type/battery
location = parts[2]
type = parts[3]
icinga2_payload = {
'plugin_output' : "BATT {0}: {1}%".format(code, battery),
'service' : "{0}!battery".format(host),
'performance_data': [ "battery={0}%;{1};{2}".format(battery, batt_warn, batt_crit) ],
So once you establish the required payload for an icinga2 check it becomes pretty easy to add.
You then have to define the host/service/checkcommand in your icinga2 config and away you go. I won’t go into the icinga2 config as that is a whole new kettle of fish!
But the key bits from this are mqttwarn
. Using this tool it is very easy to take data from MQTT topics and transform it into something useful for another service. Without having to touch any openHAB config. I already had all my sensor data being published to MQTT topics in the hope I would one day be able to use it - and along came icinga2!
The real beauty of icinga2 is the ability to configure how and where you are notified. For example by default a service won’t send a notification until it has failed 5 checks (checks are typically executed every minute but this is of course configurable).
I have my system setup to publish alerts to Pushover (again via mqttwarn
) and also direct to a private Slack channel;
Here is a screenshot of my hallway pir sensor (a host) with 4 services being checked by icinga2;
