I’ve been using @bartus items, sitemaps and rules for the Monoprice 6-zone for a few years and it’s been great.I just upgrade to 2.5 and it is no longer working for me.
Should the “old” method still work? If so, any suggestions on what needs to be done for 2.5 compatibility?
I see that @ccutrer wrote a binding but I don’t see it available under 2.5 paperUI. Is this considered the “replacement” method and if so do I need to manually install this?
If someone can point me in the right direction it would be greatly appreciated.
There is a near infinity contained in the words “no longer working”. Do you see errors in the logs? Do you see indication that the necessary events are happening to trigger the Rules? Do you see evidence that the Rules are running?
I apologize for my post for help which was lacking details. TBH, I assumed it was a known issue upgrading and that I needed to change my method. Since others such as @swamiller indicated that they didn’t need to make changes when going to 2.5 or 2.51, I realized I needed to look into this deeper.
At first I had a lot of errors with my items, rules and sitemaps after upgrading to 2.5. I started commenting out things which I thought might cause problems, like my monoprice info. I don’t know if it was related but my problem with nothing showing on the sitemap/interfaces resolved itself. Sine then I put my old sitemaps, rules and items files back. I’m still not able to control my monoprice amp.
If I try to turn a zone on from my sitemap I get:>
2020-01-14 20:04:14.747 [INFO ] [pse.smarthome.model.script.MonoPrice] - Zone 1 Power ON
2020-01-14 20:04:14.758 [ome.event.ItemCommandEvent] - Item 'AudioMTX' received command ?11
2020-01-14 20:04:14.766 [vent.ItemStateChangedEvent] - AudioMTX changed from <11PR01
to ?11
2020-01-14 20:04:15.068 [vent.ItemStateChangedEvent] - MonoPrice_Status changed from ?12 to ?11
2020-01-14 20:04:15.406 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'MonoPrice Status on command change': No match found
If I try to change the status on the Monoprice device, I get nothing at all.
My guess is the problem is related to
Could not open serial port /dev/ttyUSB0: Serial port ‘/dev/ttyUSB0’ could not be found. Available ports are:
That error means the serial devices either doesn’t exist or it’s permissions are such that the OH user cannot read/write to it. Assuming the error is coming from the amp, that means oh can’t communicate with the amp. You need to figure on why the device isn’t there. A first step is to restart the machine.
And that would be the last step since it worked. While the machine/Pine64 rebooted after the upgrade, I guess it needed another one since communication with the USB/serial was lost.
I greatly appreciate the help. One nice thing to come out of this issue is that I now know of some enhancements to what I was using before.
Edit: I guess I didn’t realize that whenever I do an update that I will need to update as the serial interface drops and I then get a ton of errors.
Sorry to revive this topic, but I am having issues with my new monoprice 6 zone amp and was hoping someone could point me in the right direction. My hunch is the amp version is a little different, hence my problems, but I can’t figure out which parts I might need to adjust. I’m running OH 2.5.3 on a fresh install of openhabian. I’ve rebooted countless times and ensured openhab is in the dialout group to no avail.
I am using the items, rules, and sitemap from the first post. When I adjust from the sitemap I get the “No match found” error that was mentioned before. When I adjust from the amp, though, the AudioMTX item gets updated like so:
2020-04-18 12:44:33.943 [vent.ItemStateChangedEvent] - AudioMTX changed from ?1PR1+ to ?1VO14+
2020-04-18 12:44:34.487 [vent.ItemStateChangedEvent] - AudioMTX changed from ?1VO14+ to ?1VO15+
2020-04-18 12:44:34.939 [vent.ItemStateChangedEvent] - AudioMTX changed from ?1VO15+ to ?1VO16+
2020-04-18 12:44:35.143 [vent.ItemStateChangedEvent] - AudioMTX changed from ?1VO16+ to ?1VO17+
So the communication seems to be there, but it doesn’t do anything else. I also installed the binding referenced above and everything said ONLINE, but I couldn’t control anything. This is why I think openHAB and the amp are talking to one another, but the amp is saying something other than expected.
I am using the Monoprice 31028 (manual here pages 22-24), and I think maybe this was written for 10761.
At this point I’m just hoping someone can confirm that is the issue, then maybe I can figure out how to adapt the code to what I need.
It isn’t perfect, but it works well enough for my purposes. Changes I had to make:
Since the 30128 doesn’t have the master/slave function the zone numbers are all just single digits.
Some of the acronyms change when you are sending commands to the unit (BL for balance in the original code, BA in mine)
“+” added to the end of commands sent to the unit, and < changed to !.
Zone status updates only send five variables (3ZS VO8 PO1 MU0 IS0+ - zone number, volume, power, mute, and input select). Sometimes after it received a command it would append that commend to the beginning of the status update (?3VO8+#3ZS VO8 PO1 MU0 IS0+), which messed up getting the proper zone number. Had to play around with the regex to to make this work consistently.
The unit only has two inputs, either the line for the zone or a bus shared by all zones.
You can adjust balance, treble, and bass, but these values aren’t sent as part of the zone status. (I assume the other unit reports all at once?) You can query these individually, though. My adjusted code can adjust these values, but won’t change it if it is changed through the remote or is reset for some reason.
I’m sure there were other adjustments I made, but they are escaping me right now. And this is all a hobby for me, so I am sure I’ve missed something somewhere along the line. It all seems to work, though!
import java.util.regex.Matcher
import java.util.regex.Pattern
var String zone
rule “MonoPrice Status on command change”
Item MonoPrice_Status changed or
System started
var String MonoPrice_ResponseExpr = “.*#(\d+)ZS VO(\d+) PO(\d+) MU(\d+) IS(\d+)\+”
var Pattern pattern = null
var Matcher matcher = null
pattern = Pattern::compile(MonoPrice_ResponseExpr)
matcher = pattern.matcher(AudioMTX.toString)
matcher.find()
Thread::sleep(300)
for(var int i = 1; i <= gMonoPriceStatus.members.size; i=i+1){
postUpdate(“MonoPrice_Status_G”+i, matcher.group(i))
rule “Volume (G2) Update”
Item MonoPrice_Status_G2 received update
val Number vol = ((MonoPrice_Status_G2.state as DecimalType) / 38 * 100).intValue
val int num = Integer::parseInt(MonoPrice_Status_G1.state.toString)
postUpdate(“MonoPrice_Z”+num+"_Volume", vol.toString)
logInfo(“MonoPrice”, "Volume updated to zone " + num + " Volume level " + vol)
rule “Power (G3) Update”
Item MonoPrice_Status_G3 received update
if(MonoPrice_Status_G3.state == “1”){
val in num = Integer::parseInt(MonoPrice_Status_G1.state.toString)
postUpdate(“MonoPrice_Z” + num + “_Power”, “ON”)
else {
postUpdate(“MonoPrice_Z” + num + “_Power”, “OFF”)
rule “Mute (G4) Update”
Item MonoPrice_Status_G4 received update
if(MonoPrice_Status_G4.state == “1”){
postUpdate(“MonoPrice_Z”+num+"_Mute", “ON”)
else {
postUpdate(“MonoPrice_Z”+num+"_Mute", “OFF”)
rule “Source (G5) Update”
Item MonoPrice_Status_G5 received update
val sor = MonoPrice_Status_G5.state
postUpdate(“MonoPrice_Z”+num+"_Source", sor.toString)
logInfo(“MonoPrice”, "Source updated to zone "+ num + " Source Number " + sor)
rule “Refresh Switch” //used during system startup, cycle through each zone
Item MonoPrice_Refresh received command ON or
System started
for(var int i=1; i <= 6; i = i+1){
AudioMTX.sendCommand("?"+i+“ZS+\r”)
Thread::sleep(600)
MonoPrice_Status.postUpdate(AudioMTX.state.toString.trim)
logInfo(“Monoprice”, “Monoprice Amp items refreshed”)
rule “MonoPrice Zone Power”
Item MonoPrice_Z1_Power received command or
Item MonoPrice_Z2_Power received command or
Item MonoPrice_Z3_Power received command or
Item MonoPrice_Z4_Power received command or
Item MonoPrice_Z5_Power received command or
Item MonoPrice_Z6_Power received command
Thread::sleep(100)
val power = triggeringItem as SwitchItem
switch power {
case MonoPrice_Z1_Power: zone =“1”
case MonoPrice_Z2_Power: zone =“2”
case MonoPrice_Z3_Power: zone =“3”
case MonoPrice_Z4_Power: zone =“4”
case MonoPrice_Z5_Power: zone =“5”
case MonoPrice_Z6_Power: zone =“6”
if(receivedCommand==ON){
AudioMTX.sendCommand("!" + zone + “PR1+\r”)
logInfo(“MonoPrice”, “Zone “+ zone + " Power ON”)
else if(receivedCommand==OFF){
AudioMTX.sendCommand(”!" + zone + “PR0+\r”)
logInfo(“MonoPrice”, “Zone " + zone + " Power OFF”)
AudioMTX.sendCommand("?" + zone + “ZS+\r”)
Thread::sleep(300)
rule “MonoPrice Zone Volume”
Item MonoPrice_Z1_Volume received command or
Item MonoPrice_Z2_Volume received command or
Item MonoPrice_Z3_Volume received command or
Item MonoPrice_Z4_Volume received command or
Item MonoPrice_Z5_Volume received command or
Item MonoPrice_Z6_Volume received command
Thread::sleep(100)
val volume = triggeringItem as DimmerItem
var Number volume_z
switch volume {
case MonoPrice_Z1_Volume: zone =“1”
case MonoPrice_Z2_Volume: zone =“2”
case MonoPrice_Z3_Volume: zone =“3”
case MonoPrice_Z4_Volume: zone =“4”
case MonoPrice_Z5_Volume: zone =“5”
case MonoPrice_Z6_Volume: zone =“6”
if(receivedCommand instanceof PercentType) {
volume_z = receivedCommand
volume_z = (volume_z * 38 / 100).intValue
} else {
if(receivedCommand==INCREASE)
volume_z = volume_z + 1
if(receivedCommand==DECREASE)
volume_z = volume_z - 1
if (volume_z>9) {AudioMTX.sendCommand("!" + zone + “VO” + volume_z.toString + “+\r”) }
else {AudioMTX.sendCommand("!" + zone + “VO0” + volume_z.toString + “+\r”) }
volume.postUpdate((volume_z / 38 * 100).intValue)
Thread::sleep(300)
rule “MonoPrice Zone Mute”
Item MonoPrice_Z1_Mute received command or
Item MonoPrice_Z2_Mute received command or
Item MonoPrice_Z3_Mute received command or
Item MonoPrice_Z4_Mute received command or
Item MonoPrice_Z5_Mute received command or
Item MonoPrice_Z6_Mute received command
Thread::sleep(100)
val mute = triggeringItem as SwitchItem
switch mute {
case MonoPrice_Z1_Mute: zone =“1”
case MonoPrice_Z2_Mute: zone =“2”
case MonoPrice_Z3_Mute: zone =“3”
case MonoPrice_Z4_Mute: zone =“4”
case MonoPrice_Z5_Mute: zone =“5”
case MonoPrice_Z6_Mute: zone =“6”
AudioMTX.sendCommand("!" + zone + “MU1+\r”)
logInfo(“MonoPrice”, “Zone “+ zone + " Mute ON”)
AudioMTX.sendCommand(”!" + zone + “MU0+\r”)
logInfo(“MonoPrice”, “Zone " + zone + " Mute OFF”)
AudioMTX.sendCommand("?" + zone + “+\r”)
Thread::sleep(300)
rule “MonoPrice Zone Source”
Item MonoPrice_Z1_Source received command or
Item MonoPrice_Z2_Source received command or
Item MonoPrice_Z3_Source received command or
Item MonoPrice_Z4_Source received command or
Item MonoPrice_Z5_Source received command or
Item MonoPrice_Z6_Source received command
Thread::sleep(100)
val source = triggeringItem as NumberItem
switch source {
case MonoPrice_Z1_Source: zone =“1”
case MonoPrice_Z2_Source: zone =“2”
AudioMTX.sendCommand("!" + zone + “IS” + source.state.toString + “+\r”)
Thread::sleep(300)
rule “MonoPrice Zone Tone”
Item MonoPrice_Z1_Treble received command or
Item MonoPrice_Z2_Treble received command or
Item MonoPrice_Z3_Treble received command or
Item MonoPrice_Z4_Treble received command or
Item MonoPrice_Z5_Treble received command or
Item MonoPrice_Z6_Treble received command or
Item MonoPrice_Z1_Bass received command or
Item MonoPrice_Z2_Bass received command or
Item MonoPrice_Z3_Bass received command or
Item MonoPrice_Z4_Bass received command or
Item MonoPrice_Z5_Bass received command or
Item MonoPrice_Z6_Bass received command
var Number toneslider_z
var String tone_z
Thread::sleep(100)
val tone = triggeringItem as DimmerItem
switch tone {
case MonoPrice_Z1_Treble: {
zone =“1”
tone_z = “1TR”
case MonoPrice_Z2_Treble: {
zone =“2”
tone_z = “2TR”
case MonoPrice_Z3_Treble: {
zone =“3”
tone_z = “3TR”
case MonoPrice_Z4_Treble: {
zone =“4”
tone_z = “4TR”
case MonoPrice_Z5_Treble: {
zone =“5”
tone_z = “5TR”
case MonoPrice_Z6_Treble: {
zone =“6”
tone_z = “6TR”
case MonoPrice_Z1_Bass: {
zone =“1”
tone_z = “1BS”
case MonoPrice_Z2_Bass: {
zone =“2”
tone_z = “2BS”
case MonoPrice_Z3_Bass: {
zone =“3”
tone_z = “3BS”
case MonoPrice_Z4_Bass: {
zone =“4”
tone_z = “4BS”
case MonoPrice_Z5_Bass:{
zone =“5”
tone_z = “5BS”
case MonoPrice_Z6_Bass: {
zone =“6”
tone_z = “6BS”
toneslider_z = receivedCommand
toneslider_z = (toneslider_z * 14 / 100).intValue
} else {
toneslider_z = toneslider_z + 1
toneslider_z = toneslider_z - 1
AudioMTX.sendCommand("!" + tone_z + toneslider_z.toString + “+\r”)
tone.postUpdate((toneslider_z / 14 * 100).intValue)
AudioMTX.sendCommand("!" + zone + “TR+\r”)
Thread::sleep(300)
rule “MonoPrice Zone Balance”
Item MonoPrice_Z1_Balance received command or
Item MonoPrice_Z2_Balance received command or
Item MonoPrice_Z3_Balance received command or
Item MonoPrice_Z4_Balance received command or
Item MonoPrice_Z5_Balance received command or
Item MonoPrice_Z6_Balance received command
var Number balance_z
val balance = triggeringItem as DimmerItem
Thread::sleep(100)
switch balance {
case MonoPrice_Z1_Balance: zone =“1”
case MonoPrice_Z2_Balance: zone =“2”
case MonoPrice_Z3_Balance: zone =“3”
case MonoPrice_Z4_Balance: zone =“4”
case MonoPrice_Z5_Balance: zone =“5”
case MonoPrice_Z6_Balance: zone =“6”
balance_z = receivedCommand
balance_z = (balance_z * 63 / 100).intValue
} else {
balance_z = balance_z + 1
balance_z = balance_z - 1
AudioMTX.sendCommand("!" + zone + "BA" + balance_z.toString + "+\r")
balance.postUpdate((balance_z / 63 * 100).intValue)
AudioMTX.sendCommand("?" + zone + "BA+\r")
Thread::sleep(300)
I’ve incorporated the binding into my own setup, and it’s working very well (much faster than the original rules). I’ve retired the old rules file and modified my items to access the thing channels now. For anyone moving over to this binding, here is my configuration for reference:
I have done some new modifications to the Monoprice binding code. I have added support for the Monoprice 31028 as well as Xantech 8x8 amplifiers which use a similar protocol. I have tested the changes with the originally supported Monoprice 10761/Dayton DAX66 and there seem to be no issues. The beta version of the binding with these changes is available to install via the Add-on Marketplace.
There is some good information about the other amps’ communication protocols here:
Just a quick note…
I have finished and opened a PR for the changes to support additional amplifiers including the Dayton DAX88. The new version is available to install via the Add-on Marketplace. I have tested the changes and so far found no regressions in the original functionality for the 10761 amplifier. If anyone has time to test out the Marketplace version, please report any issues found.
